Results 1 to 7 of 7
    New ROGer Array
    Oct 2011
    Location
    Denmark
    6
    G74SX Function (Fn) key driver
    I tried to remove a lot of the default software that comes with my G74SX, but I guess I somehow removed the driver that enables the Fn key.
    Right now I cannot use any of the special functions like turn volume up/down/off etc
    Can someone tell me which piece of software I need to reinstall in order to get this function working again?
    Thanks,
    Stunt
    ROG Guru: Blue Belt Array fuzon1337's Avatar
    Sep 2011
    Location
    Norway
    18
    878
    Hi
    Download the ATK package from Asus Support.
    Then the Fn should work fine again
    New ROGer Array
    Oct 2011
    Location
    Denmark
    6
    Hmm I didn't uninstall the ATK package, but I will try re-installing it and see if it helps.
    Thanks!
    Sep 2011
    Location
    Norway
    18
    878
    Hmm, just let us know, since the ATK package is the drivers to use the Fn keys
    New ROGer Array
    Oct 2011
    Location
    Denmark
    6
    Reinstalling ATK drivers fixed the problem!
    Thanks!
    Sep 2011
    Location
    Norway
    18
    878
    Good it worked out for you
    No problem
  7. #7
    New ROGer Array
    Aug 2013
    1
    This worked for me as well. Loaded Win 7 64bit on this laptop and everything was fine except for FN keys which i just ignored. Well after turning the Wireless switch on the right side off and on I was unable to get wireless adapter working. Its Installed and showing up in Network Connections however windows would not recognize the adapter as being turned on.
    Loaded the ATK package and all my FN functionality was back to normal. Enabled the wireless adapter with FN + F2 and its working again.
    Thanks
Similar Threads
  1. Best driver for ati 5870
    By Bonus Da Housecat in forum G Series Gaming Notebooks
    Last Post: 07-23-2013, 04:27 AM
  2. Something New in Sentelic Driver?
    By JRd1st in forum G Series Gaming Notebooks
    Last Post: 10-19-2011, 09:26 PM
  3. GeForce 275.33 Driver is official
    By Brian@ASUS in forum Nvidia Graphics Cards
    Last Post: 06-01-2011, 06:06 PM
  4. What driver for my SSD?
    By Barso in forum Other Series Motherboards
    Last Post: 05-15-2011, 08:33 PM
  5. Replies: 1
    Last Post: 01-30-2011, 07:06 PM
Tags for this Thread
