Realtek Audio drivers G73SW
Icemanforlife
I currently have the Realtek drivers 6.0.1.6162 published in 7/21/2010 for the G73SW. Are the ones listed on
http://www.asusrog.com/forums/showthread.php?1150-G73-74-53-Series-Driver-and-Application-Reference
Realtek Audio driver v2.63 (07/20/11)
the correct drivers for this laptop and has anyone seen a audio quality improvement by updating to the newest version if so? The reason why i ask about the drivers is that i am hoping it will fix the problem i have with my speakers being fuzzy on certain bass notes seen in a post i did earlier.
http://www.asusrog.com/forums/showthread.php?4644-G73SW-XT1-sound-has-static&highlight=static
6 REPLIES 6
JRd1st
Level 12
I don't think any driver will fix that problem. It sounds like something is being vibrated by the speaker, or the speaker is vibrating against its mount.
That's a fairly common occurrence, it seems. Here's an example- http://forum.notebookreview.com/asus-gaming-notebook-forum/616055-how-disassemble-g74sx-reduce-speak...
Read the User's Manual for more info. 😄
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
LG E2350 LED LCD Monitor
Intel Series 510 120 GB SSD
Drivers, Apps and How To's
Latest nVidia Drivers
JRd1st on DeviantArt.com
Icemanforlife
Are those the right drivers though for my laptop if i was wanting to update them?
xeromist
I think that's the driver that I used for my JH but you should probably check to see if there is a newer one on the ASUS website or on Realtek before you install. Chastity is on hiatus for a while so they may not be the latest and greatest.
Retired
Not applicable
There is a bug with the 2.66 Realtek High Definition Audio Codec driver. When you click the bubble to disable 'show the notification area icon' it will not disable it the next time you restart your computer. I disable the Realtek HD Audio Manager in System Configuration anyways.
Thanks for telling us. 😄 Did you tell Realtek, too?
G74SX-A1 BIOS 203
Intel 6230 WiFi/BT
Retired
Not applicable
Realtek should already know by now. They update their drivers about every two or three weeks and you'll most likely see the change. Sometimes they update their drivers within a couple days.
