Results 1 to 3 of 3
    New ROGer Array
    Nov 2011
    Location
    Seattle
    9
    Angry Graphics Card Problems-G73jh
    I have a g73jh i got from Best Buy, I have spent the past two days looking around for a solution to this problem, it did not exist when I first got it, and only began this weekend (roughly a year after I got the laptop)
    MY graphics Card is a ATI Mobility Radeon HD 5800
    My problem is this, I get a corrupted screen (imaged below) when I do one of the following
    1- watch a youtube video, both embedded or on site- flash content works fine
    2- play select games, counterstrike is an example, just cause 2 works fine
    3- unplug the laptop on have it run off battery
    if I close the troublesome program/video or plug the laptop back in the screen returns to normal
    I attempted to use the GSOD fix, but this only made the screen become corrupted ALL the time, instead of just with certain programs- I flashed my Vbios back to the stock version
    I did update the drivers to both the newest from ATI and the one from the Asus website- no change
    I did run some stress tests like FurMark- it told me the card was at 70* the whole time
    So does Speed fan, but BurnIntest says it went up to 90.....
    I would really appreciate some help!
    New ROGer Array
    Nov 2011
    Location
    Seattle
    9
    Bump- could really use some help
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    Location
    USA
    89
    4,437
    Does the corrupt display also occur on a secondary monitor? If not, you may have a poorly seated LCD video cable. If so, you may have a faulty GPU.
    If you just purchased this laptop, I would go to the retailer and ask for an exchange to a new model without this issue.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
Similar Threads
  1. G53SW graphics card upgrade
    By Donald_W in forum G Series Gaming Notebooks
    Last Post: 02-27-2013, 03:12 AM
  2. graphics card
    By william131313 in forum G Series Gaming Notebooks
    Last Post: 11-29-2012, 10:46 AM
  3. Help with G73JH graphics card going out?
    By Del87 in forum G Series Gaming Notebooks
    Last Post: 07-30-2011, 01:02 AM
  4. ASUS MARS II Graphics Card Pictured
    By ottoyu34 in forum Overclocking & Tweaking
    Last Post: 07-01-2011, 07:36 PM
  5. G60JX graphics card
    By Jonny Q Ball in forum G Series Gaming Notebooks
    Last Post: 03-22-2011, 09:43 PM
