+ Reply to Thread
Page 4 of 9 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 85
Thread: ASUS Rampage IV Extreme - Easy Overclock Guide
  1. #31
    ROG Member noemzan +10
    Mar 2012
    12
    Gamers OC Preset Help
    Running the i7-3820 on a Rampage IV Formula and was trying out the "Gamers OC(4.7Mhz)" preset profile.
    Now my rig should be more than capable to handle the OC but for some reason it only gets 4.3Mhz and Not 4.7Mhz???
    Sure Im missing something?
    Would be a great help if someone could help me out with this.
    CPU: Intel Core i7-3820 3.6GHz LGA2011 10MB 130W
    Motherboard: Rampage IV Formula Intel® X79
    MEM: Corsair 16GB (4x4GB) DDR3 1866MHz / PC3-15000 CL9 DIMM 240-Pin DOMINATOR GT
    GPU: XFX ATI Radeon 7970 HD DD 1000MHz 3GB PCI Express 3.0 HDMI Black Edition
    SSD: Corsair Memory 120GB Force Series 3 SATA 6Gb/s 2.5" Solid State Drive (Read 550MB/s, Write 510MB/s)
    PSU: Corsair 1200 Watt Pro Series AX1200
    CPU Cooler: Corsair Hydro Series H100 High-Performance
    Case: Corsair Carbide Series 500R
    OS: Windows 7 Ultimate Edition 64bit
  2. #32
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,798
    Probably because you are using a 3820 which is CPU multiplier limited.
    ASUS Technical Marketing
    If you are located outside North America and require technical assistance or support, please contact ASUS Support for your region.
    For ASUS North America Service: http://www.service.asus.com/#!contact-us/cw8z
  3. #33
    Mar 2012
    12
    solution?
    Thanks for the quick reply man.
    Is there a way around it? As I'm sure you've seen that this chip can be OC'd to 5Mhz.
    Id be happy with between 4.5Mhz or a 4.7Mhz.
    Thanks again.
  4. #34
    Apr 2011
    Location
    ASUS North America
    2,798
    You'll have to use a combination of multiplier, straps (whatever you have available) and BCLK. I would use the 125 strap to get the frequency if you can - can't recall what the max multiplier ratio is on these CPUs as I have never used one. In BIOS you can see the target CPU frequency in the top left hand corner of the screen.
  5. #35
    Mar 2012
    12
    Will do a bit more research and try it out tonight.
    Thanks
  6. #36
    ROG Guru: White Belt Hyper +10 Hyper's Avatar
    Feb 2012
    80
    I must have some basic settings wrong , even if I change my ram to it's allocated Mhz the PC refuses to boot.
    Any advice Raja?
    3930K
    RE4
    16Gb G-Skill Rip Jaws 1866
    Regards
  7. #37
    Apr 2011
    Location
    ASUS North America
    2,798
    What DRAM timings, CPU frequency, voltages etc?
  8. #38
    Feb 2012
    80
    Quote Originally Posted by Raja@ASUS View Post
  9. #39
    Apr 2011
    Location
    ASUS North America
    2,798
    what happens when you set XMP?
  10. #40
    Feb 2012
    80
    errrrrrrmmmmm , it runs like a charm @ 4.3Ghz & ram @ 1866Mhz
    Cheers bro
+ Reply to Thread
Similar Threads
  1. ASUS Rampage IV Extreme - UEFI Guide for Overclocking
    By Raja@ASUS in forum Rampage Series Motherboards
    Last Post: Yesterday, 06:48 PM
  2. Replies: 13
    Last Post: 04-05-2012, 04:18 PM
  3. How to Overclock ASUS RAMPAGE III Extreme BIOS GUIDE
    By V2-V3 in forum Rampage Series Motherboards
    Last Post: 10-13-2011, 12:57 AM
  4. ASUS Rampage III Extreme Overclocking BIOS Guide
    Last Post: 10-11-2011, 09:23 PM
