extreme iv-z not seen bios fault
Retired
Not applicable
Hi All,
Im new and have a question.
My bios is all scrambled and wierd, I think it is video related because i see the same thing when some people overclock their videocard and getting artifacts.
The bios windowshell itself is ok,but where i can change values is all screwed (purple stripes and scrambled). windows is starting normal and games are fine also benchmarks.
Alse the resolution is wrong its like 300x500 or so, it goes outside the monitor. I can`t see the C6 state for example. I`ve searched a lot, but ...nothing.
Specs : asus extreme iv-z, i7 2600k, watercooled with 2 xfx 6870`s.
I hope someone can help me
KILLER_K
Sounds like a gpu issue also to me. Do you have a spare one you can try out in the board? What kind of power supply are you using.? And did you double check nothing is grounding out and everything is seated properly? Thanks
Retired
Not applicable
powersupply is 1000W watercooled,must be enough . I can try to put my old card back 8800gt to see if thats the problem. Thats the problem with watercooling 😄 drain the loop again.
Can i just put the pci-e lanes off with the switch and the i7 onboard videochip will take over?
cheers
