03-30-2015 04:20 AM - last edited 3 weeks ago by ROGBot
03-30-2015 05:05 AM
03-30-2015 08:06 AM
TulnukaWara wrote:
Hey, i was thinking to make some extra intake openings to Asus rog g750js bottom side. I just thinking, that is this any worth?. I know that this cooling is built to take air from the ram cover so its cooling hdd-s and allso ram. But its too hot when it reaches fans. And i was thinking... if i make some extra intake near cooling fans, it will improve the temps for cpu and gpu. And im thinking that if cpu and gpu are cooler, then the whole laptop is cooler. (ram,hdd included) So what do you think? Is it worth it? Have anyone done it before ?
TulnukaWara wrote:
I was thinking to do it like this 🙂 This position is right under fan intake 🙂
03-30-2015 08:12 AM
03-30-2015 08:24 AM
TulnukaWara wrote:
ok then, i guess i have to use cooling pad then 🙂 but i just couldnt leave the original Asus thermal paste because i had gpu temps up to 92c. It was too much 🙂 But ok then that was bad idea i guess 🙂
03-30-2015 09:19 AM
03-31-2015 03:36 AM
TulnukaWara wrote:
i think i will buy some mechanical keyboard, and 27" monitor and use cooling pad for better thermals. Because i use this laptop mainly stationary. But thanks for the fast feedback 🙂
03-31-2015 06:52 AM
04-02-2015 03:12 AM
TulnukaWara wrote:
Actually this cooling pad makes difference. If its cooling the laptop case from under it , then fans allso get more cooled air in. I touched the plastic bottom plate on laptop after gaming on cooling pad. And it was cool. Actually i got 1-5c temp drop from it. And whole laptop is so cool. Top aluminum cover is so cold that its even not comfortable to hold hands on it. So it makes difference. I dont know why, but maybe i have some kind of factory fault with my laptop. But it does not matter. And i plan to keep my laptop open all times, because i want to use that monitor for second one. I just ordered Benq rl2755hm monitor and i have Razer Deathadder. I will buy some mechanical keyboard allso, but not sure what. And i use cooling pad. So i think its a myth that cooling pads are not useful for g750 🙂 I see difference. Its not big difference but if i use it for stationary setup and i dont have to use laptop keyboard, its good enough for me. And hdd and ssd runs ~10c cooler with that cooling pad. Its a fact 🙂
04-01-2015 10:49 AM
