Hi everyone, just wanted to stop in and say I love the ROG community and decided to write up a quick upgrade list that I have made, the purpose of doing this is to take some of the footwork out of finding upgrades and possibly help some of you.
First off I have the G73JH-RBBX05 from Best Buy. It's the model that had 6gb of ram and just one 500gb Hard Drive, as far as I know there seems to be a few different models that have gone through Best Buy. The way I distinguish the difference in my particular model is the type of ram that was used and the type of Wireless Network Card used in my particular unit. My unit has HMT125S6BFR8C-G7 (You can check your memories manufacturer free using a program called
CPU-Z😞 Ram and Atheros AR8131 Wireless internet adapter.
On to the Upgrades thus far:Ram for the empty slot #2
Hynix (formerly Hyundai Electronics) 2gb Pc3 8500 8500s Pc8500 DDDR3 Product # HMT125S6BFR8C-G7 $44.86
Or if you have the Kingston Ram:
Kingston DDR3 PC3-10600S 1333Mhz SDRAM SODIMM, Non-ECC Product # ASU1333D3S9DR8/2$43.79
*I have heard you can up these ram modulus to 4x4gb giving you a total of 16gb of Ram (Unconfirmed) although the 3rd Dim slot requires a full Laptop tear down to reach on the opposite side of the motherboard.
Solid State Hybrid Drive:
Seagate Momentus XT 500GB 7200 RPM 32MB Cache 2.5" SATA 3.0Gb/s with NCQ Solid State Hybrid Drive$129.99
*Here is a speed test video comparing this drive to a SSD drive, a 10,000 RPM Desktop drive and a st...Results of the speed test for people without time to watch.
Individual application launch times can be found here.For me the 500gb size for mixed with the amazing speed as well as price point makes this the drive to get.
Hard Drive Cage Assembly for Bay 2:
Drive Cage Product # 13GNY81AM020-1$9.79
Half-Mini PCI-e Wifi Adapter (To replace the horrid Atheros AR8131 Wireless internet adapter):
Intel Centrino Advanced-N 6200 Network adapter Product# 622AN.HMWWB$21.67
Optic Drive Blu-ray Slim Reader (The A1 has the LG CT21N):
LG CT21N Blu-ray Reader/DVD-Writer (I'm Currently looking for a Writer that has the same dimensions)
$134.99
Total Upgrade Cost so far: $341.30
I bought a Display model and payed around $950.00 so these upgrades were well worth it for me.
Well that's it so far, hope this helps at least some people. Everything listed is super easy to change out beside the Blu-Ray drive but that is not so bad.
My Laptop went from a 5.9 Windows Experience Index to a 7.0 (Processor being lowest score now).
Here is a Disassembly video to let you get a feel for were parts are.This is a work in progress. I will keep updating as I do more to it or if I need to correct anything.
