Results 1 to 5 of 5
    New ROGer Array
    Nov 2011
    Location
    Poland
    2
    ASUS G53JW problem - white screen.
    Hello
    I have a problem with the laptop. From the week it happens that when you start it after a few hours longer break white image is displayed and flashing drives can be heard from the front panel LEDs, but the white image or shine or dark, but it still is white and nothing else. Only pulling the battery and disconnect from the network for a while helps. It seems as if something is not stykało on a combination of display board. After re-inserting the battery and the laptop is connected to the current work to improve and turn off and turn on and everything is ok until the next time.
    Please help
    greetings
    Martin
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    Location
    Massachusetts, US
    28
    2,225
    Try this http://www.asusrog.com/forums/showth...eros-WiFi-Card
    And if that doesn't help contact Ausu for an RMA.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    Location
    USA
    89
    4,437
    Are you showing 100% CPU Utilization when this issue occurs? Do you see anything reported in the Summary of Administrative Events in Event Viewer at the time this happens? If you know exactly what time the problem occurred, you can also look at the System and Application Event Logs from that time back 1-2 hours and see if there are any Errors or Warnings reported that could point us in a troubleshooting direction.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    New ROGer Array
    Nov 2011
    Location
    Poland
    2
    This certainly is a problem with the motherboard connection matrix, I noticed that moving the lid changes the white image in correct. I have to open the lid and check the connections.
    Aug 2011
    Location
    Massachusetts, US
    28
    2,225
    Could also be the other side of the video connection in the notebook.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
Similar Threads
  1. Asus g53jw problem with the 3 button panel upper left corner
    By solosuper in forum G Series Gaming Notebooks
    Last Post: 06-09-2014, 10:53 AM
  2. G73JW Odd "blank/white screen" on random boots. Fine once Win7 loads.
    By silentbobby in forum G Series Gaming Notebooks
    Last Post: 06-29-2012, 11:21 AM
  3. HELP, g53sw's screen becomes white
    By chemicalx in forum G Series Gaming Notebooks
    Last Post: 11-10-2011, 04:35 PM
  4. ASUS G53JW Bios Update Problem
    By adramora in forum G Series Gaming Notebooks
    Last Post: 10-27-2011, 06:20 PM
  5. Replies: 8
    Last Post: 12-07-2010, 08:57 AM
