Here are some pictures of the build process
Hardware Specs:
CPU: Core i7 875K
Motherboard: ASUS ROG Maximus III Extreme
Graphics: ASUS NVIDIA GTX 480
Memory: Corsair 4GB 2x2GB DDR3 1600MHz
Power supply: 600W SLI and Crossfire edition
Optical: ASUS SATA BluRay drive
Peripherals: PCI Wireless N card
Storage: Samsung Spinpoint F3 1TB 32MB Cache
Case: DangerDen tower 16 "Nightmare" with smoke windows
I will be add descriptions to the images
The Hardware Buffet
DangerDen Tower 16 series "Nightmare" edition with Smoke windows
Asus Maximus III Extreme Motherboard and ASUS GTX 480 NVIDIA graphics card
unboxing of the Danger Den case
Nicely wrapped acrylic panels, complete with fasteners and I/O bracket
very neat individual packaging of assembly components
Assembly manual
remove the clear wrap from the packaged panels
Layout all of the components in preparation for the build
Pealing off the protective acrylic cover
remove the protective cover from all panels
insert provided nuts into the precut holes and secure with mounting screw
Begin assembly with the front face of the Danger Den case and Motherboard tray
Tighten the front screws
Front panel and motherboard tray
line up metal I/O panel on rear acrylic panel
insert I/O screws into panel and tighten
Next install the Power supply support plate and left side support panel
....AMD 3000+, AMD x2 4600+ EE, AMD X4 955 BE C2,2x AMD X4 965 BE C3, AMD X4 970 BE C3, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD x6 1100T BE, 2x AMD FX-8120, 2x AMD FX-8150, AMD A8-3850, AMD A8-3870K, Intel i7-980x, Intel i7 2600k, Intel i7-3770K, Intel i7-3930K. Coming to me on the way: Maximus V Formula (coming), AMD A10-5800K
