+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: need help with overclocking CVF(990FX)+1866hmz+1090T
  1. #21
    ROG Guru: White Belt Fallen-Angel +10 Fallen-Angel's Avatar
    Sep 2011
    Location
    Germany
    120
    @FiNAS I didn't say the result will blow up the performance, but as you mentioned you're interested in the 2-4% on performance boost, so am I. In this case I disagree with your statement, that it's meaningless to oc the RAM and that you wouldn't notice the difference/improvement. Look at the fps from Cinebench. I mean there is an improvement in ca. 6fps from 2000MHz NB -> 2770Mhz & 1600Mhz -> 2000Mhz RAM. (compared third and second lines) [OpenGL] or even just by setting the RAM freq higher (last 2 lines) gives us ca. 2fps more. I personally think it's a good improvement.
    Nevertheless, everyone has his own opinion, and the actual discussion here goes in a wrong way. ^^
    P.S.: I also think it's better to oc the CPU itself first and generally leave the NB and RAM alone, without any exp. of overclocking. But his RAM was tested at 1866Mhz, so there must be a profile in the BIOS, according to that RAM. It makes the whole thing easier.
    Case: Cooler Master Cosmos S
    PSU: Corsair AX750
    MB: ASUS Crosshair V Formula | NB&HT Link @3052Mhz
    CPU: AMD P.II 1090 X6 @4.109Ghz
    CPU cooling: Corsair H100 push/pull outtake fans
    GPU: Sapphire HD7970 @1200Mhz
    RAM: Corsair Dominator PC-1600 @1878Mhz
    SSD: 120GB Corsair Force GT + 2x 500GB RAID0 HHDs
    F**K MAC, GAME WINDOWS, DEVELOP LINUX!
  2. #22
    ROG Guru: Yellow Belt FiNAS +20
    Jul 2011
    Location
    Somewhere
    179
    we all know how picky this motherboard is with ram, and this is why I sugested not touching the ram clocks, and leave memory tweaking to the end.
  3. #23
    ROG Enthusiast FireFlower +10 FireFlower's Avatar
    Aug 2011
    Location
    Finland
    54
    Do not overclock HT-link speed. This just causes problems and has no real gains in performance. Just leave it at that 2000MHz.
    Also when overclocking FX or Thubans with high vcores put a fan to blow air directly to VRM. They get very very hot and often cause crash eventhough cpu is still "cool" because VRM overheating protection kicks in.
    Romuluotain 6
    The "Trash satellite #6"
    Romuluotain #5
    Acer TimelineX 3820TG, Core i5-480M, HD6550M, 500GB, 4GB DDR3-1066MHz
  4. #24
    ROG Guru: Yellow Belt flearider +10
    Nov 2011
    Location
    uk
    213
    well now i have my mem back from corsair .. yay ..
    17.5x234 =4.1ghz 1.41v
    mem corsair veng 1866@1872 1.5v
    nb/cpu 1.3v
    ht 2000
    gonna leave it there for a while tho could go higher temps coming in at 40deg c idel 48 deg c load ..
    on water cooling and gonna put in another tripple rad soon as i get time ..
    this will alow more overclocking as vid card & cpu on same loop gets hot fast ..
    vid card 5870 ...
+ Reply to Thread
Tags for this Thread
