Help.. MAXIMUS V FORMULA , USB can't read any disk drive, but can read others
siryu
hi guys ,,,
can someone help me here ,,
been trying to looking at google &trying many different things ..
but all not working ..
there's this yellow exclamation mark next to any drive ( flash drive or external hdd)
try to update the driver, but failed
error code (10)
is there anybody ever have the same problem with me ?
ASUS MAXIMUS V FORMULA
Intel i7-3770K @3.50GHz
16GB Corsair (2x8GB) 1866Mhz
250GB OCZ SSD
Windows 7 64bit
10 REPLIES 10
MeanMachine
Hi siryu and Welcome to ROG
What changes have you made to your system prior to this happening? Try a system restore, if its Windows.
Those yellow exclamation marks in Device manager, Indicate an incorrect driver issue and Windows won't drive those, until the correct driver is installed. Should be obtainable from manufacturers website.
Go into Bios and check see if your drives are recognized, if you can and configure correctly.
Check your USB connections and cables,and make sure your SSD is connected to the correct SATA port.
Flash your Bios to the latest version and clear CMOS.
Check for any LEDs lighting up on MB.
Other things come to mind regarding Qcode 10 "PEI core is started" which means Pre EFI initialization. This phase of post is looking for memory then passes on to the DXE environment. but check the above first and report back.
MM
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
siryu
i did nothing,, no change anything since the beginning , couple years ago ..
there's no LED lightning..
the weird thing is the USB port can read any USB device beside flash drive & external hard drive ..
actually the USB port can read the flash drive, i can hear the sound it recognized.
but it won't show on my computer.
check it at device manager, properties , it said "This device cannot start. (Code 10) "
everything else work normal .. tried system restore , but it didnt fix it..
can't update bios yet, USB can't detect USB flash drive ..
i try to find the manual book, to need learn how to update bios without USB flash drive ..
MeanMachine
Hi siryu . These are some things you can troubleshoot with.
Code 10 in windows is rather generic, but I believe the fault lies in the driver for that specific drive.
Before you begin, right click on the "USB Mass Storage Device" in Device Manager with the Yellow Exclamation mark and click "Uninstall" then reboot Windows.
1. Try this fix first and follow these steps:
In Device Manager, click the Driver tab in the device's Properties dialog box.
Click Update Driver to start the Hardware Update Wizard.
Follow the instructions to update the driver.
2. The issue can also be caused by a corruption in the Windows Driver Cache file.
Your windows INFCACHE.1 file can be found in the C:\Windows\System32\DriverStor\ directory.
Right Click on the "INFCACHE.1" file and select "Properties"
Select the "Security" Tab and click the "Edit" button
Click "Add" and in the "Enter Object Names to select" box type the word "Administrator" and click "ok".
Click "Apply" and click "ok" to the Windows Warning Screen.
Once you are back at the "Permissions for INFCACHE.1" window, select "Administrator" and check the "Full -Control" tick box. Click "Apply" and click "YES" to the Windows Warning Screen.
Click "ok" to the rest of the screens until you are back to the location of the "INFCACHE.1" file.
Right Click on the "INFCACHE.1" file and select "Delete". (renaming the file to any other name does not work)
Restart your PC and Windows will rebuild the "INFCACHE.1" file.
Once your PC restarts. Plug in your Integral USB Flash Drive and your device should function as normal.
Other things to try using REGISTRY EDITOR. (backup your registry before you do this).
3. Try deleting the USB "Upper Filter" & "Lower Filter" Entry in Registry.
Open registry editor. REGEDIT
Locate the “UpperFilters” value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{36FC9E60-C465-11CF-8056-444553540000}
On the “Edit” menu, click “Delete”, and then click “OK”.
Locate the “LowerFilters” value under the same key in the registry:
Quit Registry Editor and restart the computer.
Barring any fault with your driver hardware, this should work, so please report back.
My System Specs:
CPU:
[/HR]
okay, i just tried it ...
all 3 steps is not working ...
step 1 . follow the update steps.
it said " The best driver software for your device is already installed "
Windows has determined the driver software for your device is up to date.
step 2 . i tried following all your steps, but after restart windows , and plug in the flash drive.
the file INFCACHE.1 is not there .. means its not auto rebuild. tried to unplug & plug it again , still the file not showing up.
so at the device manager on the drive that have yellow exclamation mark, click uninstall.
then scan for hardware changes.
after that windows tryin to install driver for the flash drive, but it failed ..
it said
" Device driver software was not successfully installed "
" Please consult with your device manufacturer for assistance getting this device installed. "
" Multiple Card Reader USB Device X Failed "
" UT163 USB Flash Disk USB Device X Failed "
the thing is its not the flash drive problem, because i tried 10 different kind USB drive , also 2 seagate expansion drive ..
and all device working normal on other desktop & laptop ..
step 3 . i tried the steps , but it seems i can't delete this key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{36FC9E60-C465-11CF-8056-444553540000}
it said " error while deleting key "
MeanMachine
Hi siryu
Ok, Well you can try "sfc /scannow" (without quotation marks) in an elevated command prompt, to see if there are any other corrupted files in windows, If it finds any, it will attempt repairs and try to fix them and if not, you may have to do a clean install of your OS.
Apart from that i'm fresh out of ideas.
My System Specs:
CPU:
[/HR]
siryu
tried " sfc/scannow "
result :
" Windows Resource Protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.log windir\Logd\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log "
i tried to find the log file , to see what it said.
but i can't open it . " access is denied "
MeanMachine
Hi siryu
If windows found corrupted files and can't fix them, you have choices.
1. Try and repair Windows. (Installation disk repair) or a complete re-installation of the OS.
2. You can attempt to read the log file yourself (difficult if you don't know what to look for). The guys at Windows Seven Forum can read it for you, and analyze).
Try here: http://www.sevenforums.com/performance-maintenance/184201-how-open-windows-cbs-log-files.html
Or here for how to read Log file: https://www.youtube.com/watch?v=9rqG59ph7y4
Access to the log file is thru an elevated command prompt.
I have found in the past that the quickest way is a complete re-installation. Its a pain I know, but an analyses of the CBS log file is time consuming and may not find the problem.
Make sure to backup any important personal files before re-installing Windows.
MM
My System Specs:
CPU:
[/HR]
siryu
i did clean install windows 7 ..
and it fixed the problem ..
thank you so much bro ,..
MeanMachine
Hi siryu
Thanks for reporting back and I'm glad it's finally sorted. Enjoy your nice new clean installation.
My System Specs:
CPU:
[/HR]
