Results 1 to 4 of 4
    ROG Member Array
    Oct 2011
    Location
    Arkansas
    11
    16
    3 way sli/ cross fire on sabertooth 990 FX
    Does the sabertooth 990 FX board support 3 way SLI/cross fire? Also how are the boards wired for PCIE EX 16x16x8x8
    or 16x16x4x4
    Thanks John
    Helium Chilled Array MarshallR PC Specs
    MarshallR PC Specs
    Laptop (Model)G46VW
    MotherboardRampage IV Gene
    ProcessorIntel Core i7-3930K
    Memory (part number)Corsair Dominator Platinum 32GB (CMD32GX3M4A2133C9)
    Graphics Card #1ROG Matrix GTX 780 Ti
    Sound CardROG SupremeFX III
    MonitorASUS VG248QE with GSync mod
    Storage #1Plextor PX-M2 SSD 120GB
    Storage #2G.Skill Phoenix Blade 480GB PCIe SSD
    CPU CoolerCooler Master Seidon 240M
    CaseCooler Master HAF-X
    Power SupplySeasonic X-750
    Keyboard Corsair K90
    Mouse ROG Gladius
    Headset ROG Orion
    OS Windows 8.1 Update 1
    Network RouterASUS RT-AC66U
    MarshallR's Avatar
    Dec 2011
    119
    5,754
    Hi jchambers:
    From this page: http://www.asus.com/Motherboards/AMD...specifications
    Slots 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
    1 x PCIe 2.0 x16 (x4 mode, black)
    1 x PCIe 2.0 x1
    1 x PCI
    This means the top 16x slot, 3rd 16x slot and bottom 16x slot are the three to use in 3-way SLI and CrossFire. The board supports both types of multi-GPU with the latest graphics drivers. Keep in mind if you're running 3-way with dual-slot GPUs the bottom slot requires extra space in the case for the graphics card to overhang.
    The 2nd 16x slot is the only one that's not suitable for graphics at 4x.
    For forum administration concerns, please now contact AkaNe@Asus.
    ROG Member Array
    Oct 2011
    Location
    Arkansas
    11
    16
    thanks so much
    New ROGer Array
    Dec 2011
    Location
    1
    _________________
