+ Reply to Thread
Results 1 to 4 of 4
Thread: G73JH Help... BSOD/Random restarts
    Unhappy G73JH Help... BSOD/Random restarts
    Hello all, I purchased my G73JH a few months ago factory refurbished. Everything was good and well until I updated my system... which I realize now could have been the issue. I get random BSOD, usually when moving the laptop (even a slight tip of the screen), random freezes and restarts, and my trackpad freezes occasionally. It's getting pretty frustrating now. I have read quite a few forums on the issues but I feel as if most of them are outdated with broken links, etc. I believe my BIOS version is 213 and I am not sure how to check vBios version. I have also updated all of the drivers. I'm not on my laptop now, but I could supply all of my system information if anyone replies. Are there any updates for these issues from Asus yet? Any help is appreciated.
    - Brittany
    ROG Guru: Gold Belt dstrakele +75 dstrakele's Avatar
    Sep 2011
    Location
    USA
    4,355
    Getting a BSOD when moving the laptop sounds like a hardware issue. If you look in the System Event Log, find the BugCheck source event(s), and report the Bug Check Code(s) listed in the event(s).
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    ROG Guru: Blue Belt fuzon1337 +10 fuzon1337's Avatar
    Sep 2011
    Location
    Norway
    881
    Hi
    Have you tried to do a clean install of Windows and seen if the same problems occurs after the install?
    Perhaps you could try to clean the register with CCleaner and see if that fixes any problems you got.
    HWInfo would be useful to find info about your notebook and temp if you need to know that
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
    ROG Guru: Black Belt BrodyBoy +20
    Oct 2011
    Location
    USA
    2,916
    Quote Originally Posted by g0dfree View Post
    What do mean by "update" here? Just Windows updates? A clean install? If you could elaborate on what exactly changed between "system-working" and "system-not-working" it'll be easier to diagnose and fix the problem.
    If you didn't re-install Windows, your best bet may be to do a System Restore. Find a restore point dated BEFORE you made the changed that adversely impacted your system.
+ Reply to Thread
Tags for this Thread
