+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Ethernet kicking in slower than applications
    ROG Guru: Yellow Belt Victus +10
    Aug 2010
    Location
    Florida, USA
    153
    I'm continuously getting my Steam pop-up saying it couldn't reach the internet. I hit retry and I'm right as rain. Curious if it's a mobo issue or possibly something else?
    CPU: Intel i7 930 @ 3.8GHz
    Mobo: ASUS Rampage III Extreme
    GPU: SLI ASUS GTX480
    Memory: 12GB Corsair Dominator GT 1600
    SSD: OCZ 120GB Vertex 2
    HDD: WD 1TB CB SATA 6GB/s
    PSU: Silverstone 1000w
    Case: Cooler Master ATCS 840
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,752
    Presumably if you were losing connectivity at the ethernet level Windows would pop up a systray notification or you would see the icon change to disconnected. Do you have a software firewall installed and are you behind a home router?
    Aug 2010
    Location
    Florida, USA
    153
    I'm on a home router but it's never given me this type of a problem. It shows it's looking for a connection in the system tray as if my computer is booting up everything out of priority almost?
    Jul 2010
    Location
    Sacramento, CA
    4,752
    Ah, so windows is losing connection as well, not just Steam? You may want to try enabling a software firewall and connect directly to your modem just to make sure it isn't a router issue. Make sure to use a different network cable as well so you eliminate that possibility. These are easy things to try before you start tinkering with your rig.
    Aug 2010
    Location
    Florida, USA
    153
    Sometimes it'll happen, others it wont. Even happens with Curse client. I think it's a hit or miss on how fast the connection is versus how fast the PC boots up. Some days are slower than others so I'll get that error possibly?
    Jul 2010
    Location
    Sacramento, CA
    4,752
    So this only happens when you boot? I thought that you were losing connection randomly even after being on for a while.
  7. #7
    Aug 2010
    Location
    Florida, USA
    153
    Sorry for my lack of specifics. It only happens on boot.
  8. #8
    Jul 2010
    Location
    Sacramento, CA
    4,752
    Do you shut your PC down or put it to sleep when you're not using it?
  9. #9
    Aug 2010
    Location
    Florida, USA
    153
    Full shutdown the proper way.
    EDIT:
    I would occasionally get a random connection drop when playing WoW and when I proceed to log back in, I hit enter to log in and the PC reboots.
  10. #10
    Jul 2010
    Location
    Sacramento, CA
    4,752
    I'd say try putting it to sleep and see if the connection still dies. You may have to try it a few times since it's random.
    And I'd still try bypassing the router to see if you still have a problem. You never know when a working router could start acting up.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
+ Reply to Thread
Similar Threads
  1. Futuremark Culls Legacy Benchmark Applications to Make Room for 3DMark 11
    By ottoyu34 in forum General Hardware, Overclocking & Tweaking
    Last Post: 10-23-2010, 04:24 AM
