+ Reply to Thread
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 44
Thread: G74sx 32gb ram?
    Question G74sx 32gb ram?
    Does my motherboard support 32GB RAM?
    I googled and some motherboards looks like they do support 32GB RAM....
    Not sure about mine....
    SiSoftware Sandra
    Computer
    Manufacturer : ASUS
    URL : http://www.asus.com.tw
    Model : G74Sx
    Family : G
    Version : 1.0
    Serial Number : B6N0AS05922622A
    Chassis
    Manufacturer : ASUS
    Type : Notebook
    Can be locked : Yes
    Version : 1.0
    Power Cord(s) : 1
    Serial Number : CSN12345678901234567
    Asset Tag : No Asset Tag
    Boot-up State : Safe
    Power State : Safe
    Thermal State : Safe
    Security State : External Interface Locked-out
    Mainboard
    Manufacturer : ASUS
    Multi-Processor (MP) Support : No
    Multi-Processing (MPS) Version : 1.40
    Model : G74Sx
    Type : Mainboard
    Version : 1.0
    Serial Number : BSN12345678901234567
    Asset Tag : ATN12345678901234567
    Location in Chassis : MIDDLE
    BIOS : 63-0100-000001-00101111-120310-Chipset
    Mainboard Properties
    Removable : No
    Replaceable : Yes
    Hot Swap : No
    On-board Devices
    To Be Filled By O.E.M. : Video Adapter (Enabled)
    To Be Filled By O.E.M. : Ethernet Adapter (Disabled)
    To Be Filled By O.E.M. : Sound Adapter (Enabled)
    Chipset
    Model : ASUS Core (Sandy Bridge) Mobile DRAM Controller
    OEM Device Name : Intel Core (Sandy Bridge) Mobile DRAM Controller
    URL : http://www.intel.com
    Revision : A10
    Bus : Intel CSI (Quick Path)
    Front Side Bus Speed : 100MHz
    Width : 20-bit / 20-bit
    HTT - Hyper-Threading Technology : Yes
    Maximum Bus Bandwidth : 400MB/s
    Maximum Power : 3.400W
    Chipset 1 Hub Interface
    Type : DMI (Direct Media Interface)
    Version : 1.00
    Number of Ports : 4
    In/Out Width : 4-bit / 4-bit
    Duplex : Yes
    Multiplier : 6x
    Speed : 200MHz
    Logical/Chipset Memory Banks
    Bank 0 : 4GB DDR3 SO-DIMM 9-9-9-24 4-33-10-5 1T
    Bank 1 : 4GB DDR3 SO-DIMM 9-9-9-24 4-33-10-5 1T
    Bank 2 : 4GB DDR3 SO-DIMM 9-9-9-24 4-33-10-5 1T
    Bank 3 : 4GB DDR3 SO-DIMM 9-9-9-24 4-33-10-5 1T
    Supported Memory Types : DDR3 SO-DIMM
    Channels : 2
    Bank Interleave : 4-way
    Memory Bus Speed : 2x 667MHz (1.33GHz)
    Maximum Memory Speed : 2x 666MHz (1.33GHz)
    Multiplier : 20/3x
    Width : 64-bit
    Integrated in Processor : Yes
    Power Save Mode : No
    Fixed Hole Present : No
    Maximum Memory Bus Bandwidth : 20.84GB/s
    APIC 1
    Version : 2.00
    Multiplier : 1/2x
    Maximum Interrupts : 24
    IRQ Handler Engaged : Yes
    Enhanced Support : Yes
    Memory Module
    Manufacturer : Samsung
    URL : http://www.samsung.com/us/
    Model : M471B5273DH0-CH9
    Serial Number : 004E87E5
    Type : 4GB DDR3 SO-DIMM
    Technology : 8x(2048Mx8)
    Speed : PC3-10700S DDR3-1334
    Standard Timings : 9-9-9-25 4-34-10-5
    Version : 1.01
    Memory DC Line : 1.500V
    Timing @ 686MHz : 9-9-9-25 4-34-10-5
    Timing @ 610MHz : 8-8-8-22 4-30-9-5
    Timing @ 533MHz : 7-7-7-19 3-26-8-4
    Timing @ 457MHz : 6-6-6-16 3-22-7-3
    Timing @ 381MHz : 5-5-5-14 2-19-6-3
    Memory Module
    Serial Number : 944340E5
    Version : 1.01
    Date of Manufacture : Sunday, May 28, 2017
    Memory Module
    Serial Number : 004E8C33
    Version : 1.01
    Memory Module
    Serial Number : 944340EC
    Version : 1.01
    Sensor
    Model : ASUSTek G74--52 BAT
    Mainboard Specific Support : No
    Sensor
    Model : Intel Core CPU [P1, C4]
    Version : 42.07
    Sensor
    Model : Intel SNB/IVB IMC
    Version : 0.09
    SiSoftware Sandra
    Computer
    Manufacturer : ASUS
    Model : G74Sx
    Family : G
    Version : 1.0
    Chassis
    Manufacturer : ASUS
    Type : Notebook
    Can be locked : Yes
    Version : 1.0
    Power Cord(s) : 1
    Power State : Safe
    Mainboard
    Manufacturer : ASUS
    Model : G74Sx
    Type : Mainboard
    Version : 1.0
    Removable : No
    Replaceable : Yes
    Hot Swap : No
    On-board Devices
    Chipset
    Revision : A10
    Version : 1.00
    Number of Ports : 4
    Duplex : Yes
    Multiplier : 6x
    Speed : 200MHz
    Channels : 2
    Multiplier : 20/3x
    Width : 64-bit
    APIC 1
    Version : 2.00
    Multiplier : 1/2x
    Memory Module
    Version : 1.01
    Memory Module
    Version : 1.01
    Memory Module
    Version : 1.01
    Memory Module
    Version : 1.01
    Sensor
    Sensor
    Version : 42.07
    Sensor
    Version : 0.09
    Sensor
    Model : Intel ICH65 HWM
    Version : 0.05
    Temperature Sensor(s)
    Board Temperature : 60.00°C
    CPU Temperature : 64.00°C
    MCH/Memory/Board Temperature 2 : 36.00°C
    Voltage Sensor(s)
    CPU DC Line : 1.226V
    Battery DC Line : 16.720V
    Power Sensor(s)
    CPU Power : 45.000W
    Capacity Sensor(s)
    UPS/Battery Capacity : 75.89Wh
    System Bus(es) on Hub 1
    Version : 2.30
    System Bus 0 : PCI
    System Bus 1 : PCIe 2.00 x16 2.5Gbps
    System Bus 2 : PCIe 2.00 x1 2.5Gbps
    System Bus 3 : PCIe 2.00 x1 2.5Gbps
    System Bus 4 : PCIe 2.00 x1 2.5Gbps
    System Bus 5 : PCIe 2.00 x1 2.5Gbps
    LPC Hub Controller 1
    Model : ASUS HM65 LPC Controller
    OEM Device Name : Intel HM65 LPC Controller
    Revision : A6
    ACPI Power Management Enabled : Yes
    Advanced TCO Mode Support : Yes
    Advanced TCO Mode Enabled : No
    High Precision Timer Enabled : Yes
    Number of Precision Timers : 8
    System Timer : 14.32MHz
    Delayed Transaction Enabled : Yes
    Disk Controller
    Model : ASUS Cougar Point Mobile 6 port SATA AHCI Controller
    OEM Device Name : Intel Cougar Point Mobile 6 port SATA AHCI Controller
    Interface : SATA
    Revision : A6
    Specification : 1.10
    Maximum SATA Mode : G3 / SATA600
    Channels : 3
    In Use Channels : 3, 100%
    Port : G2 / SATA300
    Port : G2 / SATA300
    Port : G1 / SATA150
    Audio Device
    Model : ASUS Cougar Point High Definition Audio Controller
    OEM Device Name : Intel Cougar Point High Definition Audio Controller
    Revision : A6
    Type : HD (High-Definition) Audio
    Version : 1.00
    Number of In / Out / Bi-Directional Streams : 4 / 4 / 0
    Number of Serial Data Streams : 1
    Audio Codec
    Model : Realtek Semi High Definition Audio
    URL : http://www.realtek.com.tw
    Revision : A1
    Version : 1.00
    Audio Channels : 6
    Audio Device
    Model : ASUS GF116 High Definition Audio Controller
    OEM Device Name : nVidia GF116 High Definition Audio Controller
    URL : http://www.nvidia.com
    Revision : K2
    Version : 1.00
    Number of In / Out / Bi-Directional Streams : 4 / 2 / 0
    Number of Serial Data Streams : 2
    Audio Codec
    Model : nVidia 0015h
    Revision : A1
    Version : 1.00
    Audio Codec
    Revision : A1
    Version : 1.00
    Audio Codec
    Revision : A1
    Version : 1.00
    USB Controller 1
    Model : ASUS Cougar Point USB Enhanced Host Controller #2
    OEM Device Name : Intel Cougar Point USB Enhanced Host Controller #2
    Revision : A6
    Version : 2.00
    Specification : 1.00
    Interface : EHCI
    Channels : 6
    Companion Controllers : 3
    Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
    Addressing Support : 64-bit
    Legacy Emulation Enabled : No
    USB Controller 2
    Model : ASUS Cougar Point USB Enhanced Host Controller #1
    OEM Device Name : Intel Cougar Point USB Enhanced Host Controller #1
    Revision : A6
    Version : 2.00
    Interface : EHCI
    Channels : 8
    Companion Controllers : 4
    USB Controller 3
    Model : ASUS FL1000G USB 3.0 Host Controller
    OEM Device Name : Fresco Logic FL1000G USB 3.0 Host Controller
    URL : 1B73h
    Revision : A5
    Version : 3.00
    Interface : XHCI
    Supported Speed(s) : Full (12Mbps) High (480Mbps) Super (4.8Gbps)
    SMBus/i2c Controller 1
    Model : Intel ICH SMBus
    Version : 0.05
    Specification : 2.00
    Slave Device Enabled : Yes
    PEC Support : Yes
    Speed : 100kHz
    Expansion Slot(s)
    J5C1 : PCIe x16 +3.3V Shared PME Full Used
    J6C2 (1h) : PCIe x1 +3.3V Shared PME Half Available
    J6D2 (2h) : PCIe x1 +3.3V Shared PME Half Used
    J7C1 (3h) : PCIe x1 +3.3V Shared PME Half Available
    J7D2 (4h) : PCIe x1 +3.3V Shared PME Half Used
    J6C1 (5h) : PCIe x1 +3.3V Shared PME Half Available
    J8C2 (6h) : PCIe 32-bit +3.3V Shared PME Full Used
    J6UB : PCIe x16 +3.3V Shared PME Full Available
    J15BU (1h) : PCIe x4 +3.3V Shared PME Half Available
    J13BU (2h) : PCIe x1 +3.3V Shared PME Half Available
    Performance Enhancing Tips
    Warning 102 : Memory module voltage high for a mobile computer. Use lower voltage memory.
    Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
    ROG Guru: Green Belt fostert +30 fostert's Avatar
    Oct 2011
    Location
    Penticton, British Columbia, Canada
    706
    The short answer is yes, 32GB works in the G74s.
    Check out my thread:
    http://rog.asus.com/forum/showthread...B-Memory-DIMMs...
    I have no idea if my G74SX board is identical to yours or not (hey gurus: does ASUS put the same standard motherboard in the G74 series?), but 32GB seems to work fine in my G74.
    HWINFO32 says
    Memory Capacity: 33554432 KBytes
    hopefully it is true
    ROG Guru: Yellow Belt AQUASTEVAE +10 AQUASTEVAE's Avatar
    Nov 2011
    Location
    Qamea Island, FIJI
    200
    great topic and thanks ( fostert) for taking the leap to answer such an important question.
    Asus G74Sx DH71 - 17.3-inch Full HD display (1920 x 1080) - Intel Core i7-2670QM quad-core processor (2.2 GHz with Turbo Boost 2.0 up to 3.1GHz) - NVIDIA GeForce GTX 560M 3GB GDDR5 VRAM - 16GB DDR3 SDRAM, 4 x SODIMM Sockets - Crucial M4 SATA 3 256GB SSD & 750GB 7200RPM hard drive #2 - Logitech K350 wireless wave keyboard - Logitech M570 wireless trackball - WIN 7 ULT 64BIT.
    I don't know, I just bought 2x8GB RAMs from amazon, they are coming,
    Soon I test theory
  7. #7
    ROG Member Simba7 +10 Simba7's Avatar
    Dec 2011
    Location
    Billings, MT, USA
    23
    Yes, it will work. I threw in 2x8GB Patriot sticks in my G53SX and it works perfectly. It sees 24GB at the moment, but plan on bumping it to 32GB later.
  8. #8
    Oct 2011
    Location
    706
    Looks like we'll be starting a "32Gig Club" Thread soon! Maybe the "2^5 Club"?
  9. #9
    Quote Originally Posted by Simba7 View Post
    but mine is G74SX and it says on numerous sites selling this mobo that up to 16GB RAM possible upgrade
    you are saying is that if even your lower mobo took 32GB RAM mine would defenetely accept upgrade?
  10. #10
    Dec 2011
    Location
    Billings, MT, USA
    23
    Quote Originally Posted by eurgbp2011 View Post
    The only difference between the two is size. The guts are practically the same. Even the site I bought mine from (TD) says 16GB maximum.
    The 8GB sticks are still rather new and getting easier to obtain. They do work well, though.
    Router(2xP3@1GHz,1GB RAM,18GB HDD,Allied Telesyn AT-2560FX,2xDigital DE504(QP),Compaq NC3131(DP),2xSun GigaSwift(QP),SMC 8432BTA,Gentoo Linux)
    MyWS(Phenom II X3 740@3.2GHz,8GB RAM,500MB+1.5TB+2TB HDDs,GFGTS250,LG WH12LS30 BD-RE,W7U)
    MyNB(Asus G53SX-XT1,Core i7-2630QM@2GHz,24GB RAM,2x750GB HDDs,BD-RE,W7U)
    MyMC(Pentium E5200@3.5GHz,4GB RAM,3x2TB RAID5,GFGT520,W7U)
+ Reply to Thread
Tags for this Thread
