11-22-201005:33 PM - last edited on 03-06-202403:36 AM by ROGBot
This is a guide to show you step by step o how to setup your ROG connect and RC Bluetooth. For those of you that dont know about ROG connect, its pretty much the coolest invention ever! You can remotely control and overclock your system on the hardware level. There is no software tweaking through windows OS, everything is handled directly on the IROG chip changing settings in the BIOS real time!
ROG connect is pretty straight forward: Download the latest ROG connect software and install it on your netbook or notebook. connect the ROG connect usb cable from the notebook and to the ROG connect usb port
Here we have a Crosshair IV Extreme, but it will work on all models with ROG connect support. Before opening the ROG Connect application, you need to press the ROG connect button. It will light up green when on. Then go ahead and open up the program on your notebook and you are ready to go.
As you can see here, we have changed the value of the cpu bus speed to 214, then hit apply.
and here is our result. This app is in AISUITE II. It can also be verified through CPUZ
Here is out to setup your RC bluetooth connect. Note that bluetooth connect comes only in the ROG Extreme models. Maximus III Extreme, Rampage III Extreme, Crosshair IV Extreme, and Maximus IV Extreme In this setup, we will show you how to connect using a droid (android) phone
Same here,does not connect to my Samsung i9000 and my bluetoth works the wrong way! When my device on MOBO lights up,it is inactive,when i press it again and light is out its active..... WTF Anyway,when i try and search for device from my phone it just stays searching and never finds my pc,i have had it paired but the app will not work. Great guide BTW.
for rc bluetooth to work, the light needs to be on. when the light is on the windows bluetooth software is off. this is because the protocol goes directly to the hardware and NOT through windows. for normal bluetooth services the the bluetooth button is off, then your normal bt functions in windows will turn on. its kind of backwards... no light means normal bt is on in windows. with light, means rc connect is on.
when rc connect is on, use your phone to search for rc bluetooth. once you see that and connect, open up cpu z, make a change and see if it adjusts on the fly
Yeah what a c__k i am....... Thats why they supply a Manual! I have just read that in the book Brian :3. (hands in head) Anyway back to my kickass board,thx again and i'm sure i'll be back with more stupid Questions. BTW i like it here 😛
