When I first bought my computer (in my signature) I had temperatures of 20-23 on idle (stock clocks).
Last week I completely disassembled every piece and thoroughly cleaned it with an air compressed can
I even cut open my cpu to switch the cooling paste between the cpu, perfectly cleaned all the parts and it's as good as new now.
Also repasted my video card.
But still... It's idling around 30-33 (stock clocks), when I disable X.M.P. it becomes even colder (27-30)
How come I can't get back to that glorious low temperature? (My room is on the third floor under my desk.
I was also wondering if my airflow is okay:
http://imgur.com/afIfeIkMy side panel blows air inside
I'd love to hear some solutions, thank you.
Desktop
CPU: Intel Core i7-3770K
GPU: AORUS GeForce RTX 2070 SUPER 8GB
Mobo: Maximus V Formula
RAM: G.Skill RipjawsZ 32GB DDR3
Cooler: Noctua NH-D14
Disk: SSD 1.5TB
Disk: HDD 2TB
PSU: Seasonic Platinum 1000W
Display: Samsung Odyssey G7 QLED 27", 1ms, 240hz, 1440p, 10-bit, HDR600
Speakers: KRK RP7 G4
Laptop - Asus ROG GL702VS-GC198T
CPU: Intel Core i7-7700HQ
GPU: GeForce GTX 1070 8GB
Display: 1920x1080 @75Hz, IPS, G-Sync, 1ms
RAM: 16GB DDR4
Disk: M2 SSD 256GB
Disk: HDD 1TB
