12-25-2011 09:09 PM - last edited on 03-05-2024 07:27 PM by ROGBot
12-25-2011 11:00 PM
LiveOrDie wrote:
Make sure the ram push down all the way on the side with no clip, if its not that then remove the battery and unplug the power for 5 minutes then try again.
12-26-2011 08:53 AM
12-26-2011 09:18 AM
emaratee wrote:
Tried the battery trick ... NO GOOD !! but thanks anyway ...
By the way the motherboard .. just started to go banana .. !! the debug LCD will flash all sort of code ... which I manage to capture some of it (14, 60, 61.. and AF) !!!! ... for no obvious reason !!!
I disconnected the GFX ... then restarted the board ... now it's stuck at debug code 00 !! with a pci 1-5 led (as I recall) lit green !!
Long story short ... it's packed & ready to sent off on RMA ....
All the great years with Rampage series this is one is DOA I guess ... will give a new board a try and report back once RMA is dealt with ...
Thanks for the help.
12-26-2011 10:08 AM
sisco wrote:
If you read here, gave me a similar problem, fortunately with a CCMOS is back in place, I hope some expert will be able to give an explanation even theoretically, because the code 00 is not in use.
12-26-2011 10:29 AM
emaratee wrote:
Yeah ... but my case .. it's not going into bios from day one .. no beeps nothing ..!! I've literally played all possible combinations of CPU, ram, gfx ...
RAM & GFX is tested and runs on my other system ... this is just dead strange !!
Thanks anyway.
12-26-2011 10:58 AM
sisco wrote:
He had understood that you never left, but in my case the behavior was similar, has happened because removing the MB to install the WB Kooolance, and just reinstalled the whole, had an almost identical behavior from your first starting of the engine, what I find strange is the meaning of the code 61 (NVRAM initializzation), whereas the NVRAM should be a non-volatile memory, such as CMOS, which stores the data of the devices (intrrrup etc. ..) that can still in some way can be deleted and restored.
Another strange thing in my case is the fact that dismantling and Romont PC, I have changed almost nothing, so what happened to NVRAM?
