G73JW 3D VISION ERROR!!!!!!!! -.- ?!
MISIKEX
I have a ASUS ROG G73JW (3D LAPTOP) and i bought a 3D VISION KIT, and i setup drivers, and much more, and in the end i wanted to try, but I got an error message.
"Does not meet the requirements." OMG ?!
//* Ihave the latest Notebook Driver !!!
Verde Notebook 3D Vision CD v1.38 WHQL (260.99)
Hm... I'm nervous!
Look this site: http://www.nvidia.co.uk/object/GeForce_3D_Vision_Requirements_uk.html
Notebook LCD
Asus -::- G73JW -::- 1920x1080 -::- Works with Blu-ray 3D
So, Please TELL ME WHY?!?!?!?!?!?!?!?!??!?!?!?!?!? :mad:
Retired
Not applicable
ok calm down. first of all, did you get a G73jw 3DE model or a normal G73jw? if you got a G73JW the only way you can video 3D is on a 3D capable TV that supports 1.4HDMI or a DLP 3D ready TV that is 3D vision ready.
if you are trying to use 3D directly from the notebook on a normal G73JW, it will not work! the difference between a 3D and non 3D model is the 120HZ LCD. the non 3DE model does not support 120HZ and you can not just hook up a Nvidia 3D kit expecting it to work. and if you had purchased a 3DE model, there would be no need for you to purchase a 3D kit as the notebook would already come with the kit.
