+ Reply to Thread
Results 1 to 6 of 6
Thread: ASUS Z8PE-D12 Motherboard problems
    I have been trying to find a PCI express scsi card to work with this motherboard and have yet to find one that fits. The board docs say its has PCI-E x16 slots but I have yet to find a card that actually fits in the slots provided.
    Every card I have tried does not line up with the slots and breaks.
    Begging for help here, people.. Sytems got no backup until I figure this one out.
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,747
    The blue and 3 white slots next to it are all standard pci-e slots (blue is x16, white x8 but physically the same). What cards have you tried?
    Take a look at this picture with labels:
    http://www.newegg.com/Product/ImageG...%20Motherboard
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    Yes, I saw that pic when I was trying to figure out why the cards werent fitting. The latest card I tried is the Adaptec 29320ALP-R card.
    ROG Guru: Blue Belt martin_metal_88 +10 martin_metal_88's Avatar
    Apr 2010
    Location
    Quebec
    812
    According to Adaptec site this card is a PCI-X one. It's also said that she will work with a PCI slot ( 2.2 compliant ) That's why the card break, you are trying to fit a PCI into a PCI-e...Buy a PCI-e ( 16X /8X/ 4X/ 1X ) card and she will fit.
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
    Jul 2010
    Location
    Sacramento, CA
    4,747
    Ah OK, that is a PCI-X card which is only found on *some* server boards and the slot you are putting it into is a PCI-E slot. The PCI-X slot is only found on the z8pe-d12x version. Your board will have two empty areas below the bottom PCI-E slot where the PCI-X slots would be on the X version of the board. If you want to stick with Adaptec then the only Ultra320 card they have which is designed for PCI-E (that I found) is the 29320LPE.
    http://www.adaptec.com/en-us/support.../asc-29320lpe/
    TeamROG ADMIN Brian@ASUS +10 Brian@ASUS's Avatar
    Mar 2010
    Location
    USA, Fremont
    1,927
    moving to the NON rog motherboard category
    ASUS is pronounced "Ay-SOOS"
    ROG should be pronounced "R - O - G"
    Become a fan of our facebook: www.facebook.com/ASUS
+ Reply to Thread
Similar Threads
  1. ASUS live update problems
    By zimora in forum Older G Series Notebooks
    Last Post: 12-08-2010, 12:12 PM
  2. G73 Enormous Problems [Link]
    By Hedo in forum Older G Series Notebooks
    Last Post: 09-01-2010, 11:35 PM
