Crosshair V Formula: power connectors
Elhrohir
Hi.
I have been using this mobo withouth problems, giving power using the 8 pin power connector (the one that 4 pin were covered by a plastic piece). But recently (lol) i discovered that there was another 4 pin power connector (the common ones and the ones that i have always seen).
Should i give power to the other 4 pin connector ? :S i have a 700w coolermaster 80 plus with a 560gtx connected.
please give me some advices 😄 thanks
pd: sorry for my bad spelling 😞
14 REPLIES 14
Cephas
Just use the 8pin.
The 4pin is for sub zero overclocking.
Gaming: FX-8150 @ 4.6 | Asus Crosshair V | Asus GTX580 DCII @ 885 | Corsair 800D | 8GB Dominator GT @ 1866 | 2 x Vertex 3 RAID 0
HTPC: Intel i3 2100 | Asus P8H67-M-PRO | Gigabyte GT430 | Lian Li PC-V354 | 7 TB MDADM RAID
oldbrave
Go ahead and put power to that other 4 pin connector , ASUS put it there so the CPU will have the extra power if it needs it for OCing, especially the FX CPU and not just for sub-zero OCing.
Electronic Smoke Signals From my TechnoTeepee
ASUS Crosshair V Formula AM3+ 990FX, 1703 bios
AMD FX 8350 Vishera @ 5162Mhz [21x245] 1.546v 🙂
Water Cooled - Koolance EX2-1055, CPU 370 WB, Idle=22c Load=52c
32Gb G.Skill Sniper ddr3 1600 8G X 4 , 9-9-9-24 @ 1.55v
ASUS HD7970-DC2T-3GD5, Cat 13.5 beta 2, Dell U3011 @ 2560x1600
SanDisk Extreme 120Gb SSD SATA 6Gb, 250Gb SATA 6Gb, 1Tb SATA 6Gb x2
Win 7 Ultimate 64bit, Corsair Obsidian 800D, Corsair HX1000w PSU
NemesisChild
Level 12
I would not recommend connecting the extra 4-pin to the MB if you're using a PSU that has multiple +12v rails.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
Please elaborate.
AMD FX-8350 4.615 GHZ @ 1.43v ( Stable ) * ASUS Crosshair V Formula 990FX
4Gx4 GSKILL F3-17000CL11D-8GBSR 16GB @ 2133 @ 1.63v
XSPC Raystorm RX240 Extreme Universal CPU Water Cooling Kit w/ 2 RX240 Radiator
2 Sapphire HD 7950 3GB OC Edition 1100/1500 @ 1.258v Crossfire
3 Crucial 128 GB in RAID 0 * 2 WD 1002FAEX 1TB SATA3 RAID 0 Data drive
Cooler Master Cosmos II * Enermax Revolution 85+ 1020W * Win 7 Home Premium 64 bit
NemesisChild
Level 12
There have been a number of reports regarding failure to post with the extra 4-pin.
Has to do with uneven distribution of amps, depending upon which +12v rail supplies the 4-pin connector.
SIngle +12v rail PSU's are not a problem, I can verify this since I have the 4-pin connection with my Corsair HW850W.
Roadking
The PSU in my sig is a modular with a quad + 12v rail, Ive had no problems posting with the 4 pin. Can this be detrimental to the board over time?
I haven't looked at your PSU specs, but does each +12v rail have the same amperage?
If you haven't encountered any problems so far, then you should be fine.
They are 35 amp each, and from what I have been reading, they should be fine. Thanks for the info
DaemonCantor
I don't know about the CHV but on older Motherboards this was required for Multi-GPU setups because the 4 pin AUX connector didn't carry enough power to drive the MoBo and two or more Video Cards even when they had external power plugs...when they went to the 8 pin Aux connector a lot of MoBo's did away with the 4 pin Molex connector...the other thing I've noticed is with the new FX Processors they require so much power OC'ing that people have been using the 4 pin Molex to keep from melting the 8 pin Aux connector from the power draw....
