Can you be more specific on how the software is not functioning? is it giving you an error code?
Have you re installed the operating system?
Make sure you have installed the following drivers
ATKACPI driver and hotkey-related utilities
ASUS Wireless Switch (Wireless Console3) Utility
ASUS Configuration Utility
Azurewave Wireless Lan Driver and Application *Please first install the Wireless Console Utility before this driver installation
1. Please refer to below FAQ to check your Wireless''s PID code:
http://support.asus.com/faq/asus-faq.aspx?type=7&no=1548222A-AA97-0DD4-7E09-C7785177ACC0&SLanguage=e... 2. This WLAN driver is for below PID code:
HardwareID=PCI\VEN_168C&DEV_002B
HardwareID2=PCI\VEN_168C&DEV_002A
HardwareID3=PCI\VEN_168C&DEV_0024
HardwareID4=PCI\VEN_168C&DEV_001C
