RealBench uses real, open source applications to test your PC as it would perform in RL. Although it can be competitive, it’s not primarily designed to be more hardcore and time consuming – it’s a benchmark for everyone.
Select the three tests and run the benchmark to get your result. Each test uses different parts of your PC subsystem, so all areas are covered. Share the result here on the forum to compare to others, or, compare to pre/post overclocks and pre/post upgrades to get maximum value from your PC.
Computer:
Product Series :
CPU Vendor:
CPU segment:
CPU Model:
VGA Vendor:
# of VGA:
Computer:
Compare Score User ROG Core CPU Name CPU Frequency Memory Frequency GPU Type Unlocks
2631381MicMAXIMUS VIII HEROIntel Core i7 6700K4619.1 MHz1071.1 MHz (1:16)AMD Radeon (TM) R9 380 Series
253199meankeysRAMPAGE V EXTREMEIntel Core i7 6950X4759.5 MHz1721.5 MHz (1:34)ASUS R9 295X2 Series
248788MentholRAMPAGE V EDITION 10Intel Core i7 6950X4598.9 MHz1699.6 MHz (1:34)NVIDIA TITAN X (Pascal)
228173cekimX99-PRO/USB 3.1Intel Core i7 5960X4819.5 MHz1606.6 MHz (1:24)NVIDIA GeForce GTX 980
227034GobeRAMPAGE V EXTREMEIntel Core i7 5960X4798.9 MHz1599.7 MHz (1:24)NVIDIA GeForce GTX 970
226364zamippoRAMPAGE V EXTREMEIntel Core i7 5960X4400.5 MHz1333.6 MHz (1:20)NVIDIA GeForce GTX 980 Ti
225645Arne SaknussemmRAMPAGE V EXTREMEIntel Core i7 5960X4847.0 MHz1615.7 MHz (1:24)NVIDIA GeForce GTX TITAN X
221282kisuan_hisZ10PE-D16 WSIntel Xeon E5 v33565.9 MHz1118.8 MHz (1:16)NVIDIA GeForce GTX 980 Ti
218947egon.greenberRAMPAGE V EDITION 10Intel Core i7 6950X4406.8 MHz1502.3 MHz (1:30)NVIDIA GeForce GTX TITAN X
217852NanaRAMPAGE V EDITION 10Intel Core i7 6950X4199.0 MHz1399.7 MHz (1:28)NVIDIA TITAN X (Pascal)
2113521337mnRAMPAGE V EXTREMEIntel Core i7 5960X4636.8 MHz1503.9 MHz (1:18)NVIDIA GeForce GTX 980 Ti
210610viperRAMPAGE V EXTREMEIntel Core i7 5960X4698.9 MHz1599.7 MHz (1:24)AMD Radeon R9 200 Series
209586DJGSTRIX X99 GAMINGIntel Core i7 6900K1208.3 MHz1711.8 MHz (1:34)AMD Radeon R7 200 Series
207778BradySTRIX X99 GAMINGIntel Core i7 6950X4199.0 MHz1599.7 MHz (1:24)NVIDIA TITAN X (Pascal)
207479mikeyRAMPAGE V EXTREMEIntel Core i7 5960X4443.8 MHz1354.4 MHz (1:16)NVIDIA GeForce GTX 980
206427andressergioZ10PE-D16 WSIntel Xeon E5 v31255.1 MHz1115.7 MHz (1:16)AMD Radeon (TM) R9 Fury Series
205199JeverRAMPAGE V EXTREMEIntel Core i7 5960X4570.8 MHz1523.7 MHz (1:18)NVIDIA GeForce GTX 980 Ti
204707psycoX99-DELUXEIntel Core i7 5960X4748.6 MHz1499.6 MHz (1:18)NVIDIA GeForce GTX 980 Ti
203771marcel-mischlerX99-DELUXEIntel Core i7 5960X4645.0 MHz1077.2 MHz (1:16)NVIDIA GeForce GTX TITAN X
201399retardedtimingX99-M WSIntel Xeon E5 2699 v31259.4 MHz1119.5 MHz (1:16)NVIDIA GeForce GTX 1080
1 2 3 4 5 6 7 8 9 10 11  Next
Go To Top
