Hands On: USB Spitfire Audio Dongle For Vulcan Pro & Orion Pro
Exclusively bundled with the new Vulcan Pro and upcoming Orion Pro headset is the Spitfire USB audio dongle. While the headsets themselves can plug straight into 3.5mm audio jacks on your PC or notebook, the USB audio dongle adds an interim audio processor with three buttons to enable its headphone amplifier, 7.1 virtualized surround and 'FPS Mode' tweaked audio.
The Spitfire has two 3.5mm audio sockets the headset plugs into. This means you don't have to use it all the time, even if you still want to use your Vulcan's or Orion's. The other advantage is that these are standard sockets, so you can plug the Spirfire into any headset that uses 3.5mm stereo plugs!
The fact it's USB means you bypass the internal audio on your motherboard or notebook. This can be a real boost for those with basic audio, or if you're gaming on a pre-built LAN system, in an internet cafe or a tournament PC, for example, as the Spitfire is purely plug-in-and-play; requiring no extra driver install.
The headphone amp, 7.1 virtual surround and 'FPS Mode' can be triggers by simply pressing the separate buttons, with a red backlight glowing as indication to which is turned on.
The new Vulcan Pro and upcoming Orion Pro both come bundled with the Spitfire.
Popular Posts
The ROG Kithara just benched every other gaming headset I own
Just about everything I ask for in a premium gaming headset, the ROG Kithara does with gusto.
The ROG Raikiri II is my new go-to game controller — and I can’t put it down
I'm a PC gamer who plays on the couch — and the new ROG Raikiri II is the lynchpin of my living room battlestation.
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
