Project: Immortal. Full Water Cooled PC Packed Into A Flight Case
You know that TUF motherboards are ultra-durable, but is it possible to grant them immortality? Top Chinese modder, Wei Zheng, used just this inspiration when creating Project: Immortal; his new work that encases TUF’s artic-camouflaged Sabertooth Z97 Mark S in a 'Tropicana', a classic and increasingly-rare waterproof photographic-equipment case from Europe’s leading luggage brand, Rimowa. For temperature control Zheng fitted a water cooling kit from Bitspower, with stainless steel tubing.
Wei Zheng’s ingenious method of creating impregnable strength was to combine the Sabertooth Z97 Mark S, a “motherboard that cannot be broken” with Tropicana, a “yet-to-be-broken box”. Immortal is a formidable motherboard with formidable cooling in a formidable case!
See more TUF mods in the TUF site gallery!
[gallery include="" size="large" link="file" template="file-gallery" columns="2"]
Immortal Spec:
- Motherboard: ASUS TUF SABERTOOTH Z97 MARK S
- CPU: Intel Core i7-4790K
- Graphics: ASUS GTX TITAN Black
- Cooler: Bitspower Water Cooling System
- Monitor: ASUS MB168B USB powered Full HD LCD
Other angles of the Rimowa case, and how you might use the integrated display:
Close ups of the awesome Bitspower water cooling, metal tubing and TUF Sabertooth Mark S underneath
Wei Zheng even managed to squeeze in an ROG RAIDR PCIe SSD and full cover Bitspower block on the graphics card:
More eye candy:
Popular Posts
Behind the scenes with PC modder Derek Wilson, builder of our epic new OMNI PC
Bringing OMNI to life as a 4-foot tall gaming PC was no small task—but Derek was up to the challenge.
An inside look at Ben Q’s brass-filled Blanco build
Ben Q's brass-filled Blanco build fuses a custom case and cooling hardware with ROG components for a one-of-a-kind PC.
Behind The Bunker: A Look At Snef's Combat-ready Black Ops 4 Build
Take a tour of a battle-ready PC created by renowned modder Snef and inspired by Call of Duty: Black Ops 4.
Around the world in 100 quadrillion clock cycles
The ROG Strix GL502VS has spent the last year looking for the best gaming experiences in the world and has seen everything from VR in Prague to parkour in Bulgaria.
Celebrating the globetrotting ROG Strix GL502VS with Mexico’s makerspace movement
We take an inside look at Mexico's quickly growing makerspace movement, including 3D printing ROG case mods and designing our very own custom GL502VS cover.
All Aura Sync everything: Inside Snef's Aurora Borealis-inspired build
How far can you take an obsession with RGB? Snef goes full Aurora Borelis with Aura Sync.
