ROG triple-mode gaming monitors level up with 4K panels and up to 920Hz refresh rates
undefined
Every game demands something different. AAA blockbusters stuffed with detail reward razor-sharp 4K visuals, while esports titles are all about pushing frame rates as high as possible to keep up with opponents. Some games fall between these poles and benefit from a balance of high-resolution imagery and equally high refresh rates. With the latest triple mode additions to the ROG Strix lineup, you’ll have a gaming monitor built to handle each kind of experience without compromise.
Meet the ROG Strix XG27UCMG and ROG Strix XG27ACNS: two 27-inch gaming monitors built around our latest triple mode technology, giving you the flexibility to prioritize stunning image quality, uncompromising esports performance, or a balanced profile with just a few clicks. Whether you're exploring massive open worlds in ultra-high resolution or chasing every last frame in competitive shooters, these displays are ready to adapt to the way you play.
The ROG Strix XG27UCMG unites 4K glory and triple‑mode versatility
When you want a display that can do it all — uncompromising resolution, elite refresh rates, and flexible performance modes — the ROG Strix XG27UCMG has you covered. This 27‑inch 4K IPS powerhouse delivers stunning detail at up to 4K 240Hz, giving you the image clarity of a high‑end creator display with the speed of a proper esports panel. And when you want even more frames for tournament-grade play, switch to QHD 400Hz (OC) or FHD 488Hz (OC). Triple‑mode flexibility lets you choose the perfect balance of resolution and refresh rate for every game in your library.
undefined
The XG27UCMG brings vibrant visuals with 95% DCI‑P3 coverage and VESA DisplayHDR 400, ensuring your game worlds look as rich and lifelike as they feel. With ASUS Smart Pixel technology, even lower‑resolution content gets enhanced clarity and sharpness, making this monitor a beast for both high‑end gaming and everyday use.
Connectivity is equally versatile: DisplayPort 1.4 (DSC), HDMI 2.1, USB‑C with 15W power delivery, and dual USB 3.2 Gen 2 Type‑A ports give you everything you need to hook up your gear. A built‑in KVM switch with hotkey control makes it easy to manage multiple systems from a single keyboard and mouse, perfect for creators, streamers, and hybrid setups.
DisplayWidget Center gives you a better monitor experience with automatic firmware updates and the ability to export, import, or copy pro‑streamer monitor settings with ease. And the XG27UCMG packs our ROG Gaming AI technology, including AI visual enhancements like Dynamic Shadow Boost and Dynamic Crosshair. These tools help you see enemies in dark spaces, have clearer aim on the battlefield, and more.
The ROG Strix XG27ACNS pushes QHD speed to the extreme
If raw speed is your priority, the ROG Strix XG27ACNS is ready. This 27‑inch QHD monitor features triple‑mode tech that lets you choose between QHD 475Hz (OC), FHD 620Hz, or HD 920Hz. Whether you’re grinding ranked matches or going to tournaments where frame-perfect plays are essential, this display gives you the headroom to push your skills to the absolute limit. With up to 920 frames visible every single second, you’ll never have to worry about being behind the curve.
undefined
A Fast IPS panel with 0.3ms (min) GTG response time keeps ghosting to a minimum, ensuring every flick, swipe, and snap feels crisp and immediate. The XG27ACNS delivers 95% DCI‑P3 color and VESA DisplayHDR 400, so your games' visuals are presented vibrantly and accurately.
Connectivity includes DisplayPort 1.4 (DSC), HDMI 2.1, and USB‑C with 15W power delivery, giving you flexible options for gaming laptops, desktops, and portable devices.
This monitor benefits from DisplayWidget Center for auto firmware updates and easy profile management. And you’ll also get ROG Gaming AI technology for AI visual tuning, Dynamic Shadow Boost, and Dynamic Crosshair — all designed to help you see more, react faster, and stay locked in.
For information on the pricing and availability of the ROG Strix XG27ACNS and ROG Strix XG27UCMG in your region, please contact your local ROG representative. And for a complete rundown of ROG’s Gamescom 2026 reveals, check out our big roundup.
OLED Dual mode monitors
Model Size Panel Type Resolution Priority Mode Refresh Rate Priority Mode
ROG Swift OLED PG32UCWM 32" Tandem RGB OLED 4K 240Hz FHD 480Hz
ROG Swift OLED PG27UCWM 27" Tandem RGB OLED 4K 240Hz FHD 480Hz
ROG Strix OLED XG32UQWMS 32" Tandem WOLED 4K 240Hz FHD 480Hz
ROG Swift OLED PG27AQWP-W 27" Tandem OLED QHD 540Hz HD 720Hz
ROG Swift OLED PG27AQWP-G/ PG27AQWP-GR Edition 20 27" Tandem OLED QHD 540Hz HD 720Hz
ROG Strix OLED XG32UCWMG 32" OLED 4K 240Hz FHD 480Hz
ROG Strix OLED XG32UCWG 32" OLED 4K 165Hz FHD 330Hz
IPS Dual mode monitors
ROG Strix XG27UCG Gen 2 (XG27UCGR)
27" Fast IPS 4K 162Hz FHD 485Hz
ROG Strix XG27UCS Gen 2 (XG27UCSR)
27" Fast IPS 4K 160Hz FHD 324Hz
ROG Strix XG32UCG 32" Fast IPS 4K 160Hz FHD 320Hz
ROG Strix XG27JCG 27" Fast IPS 5K 180Hz QHD 330Hz
ROG Strix XG27JCEG 27" Fast IPS 5K 80Hz QHD 320Hz
IPS Triple mode monitors
Model Size Panel Type Balanced Mode Turbo Mode Hyper Mode
ROG Strix XG27UCMG 27" Fast IPS 4K 240Hz QHD 400Hz FHD 488Hz
ROG Strix XG27ACMSR 27" Fast IPS  FHD 420Hz  HD 640Hz  FHD 420Hz
ROG Strix XG27ACNS 27" Fast IPS
QHD 475Hz
FHD 620Hz HD 920Hz
ROG Strix XG27ACMESR 27" Fast IPS
QHD 280Hz
FHD 365Hz HD 550Hz
