GX1000 Eagle Eye Gaming Mouse Hardware Overview
The GX1000 'Eagle Eye' is ROG's new laser gaming mouse. With a sensor precision range of 50 DPI to 8200 DPI and a variable weights system in the base that can change its mass between 150-175g, whatever type of gamer you are you can completely customize the mouse to meet your preferred play style. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] The weights system is easily accessed underneath. Just pop off the holder and drop in the bundled 5g weights. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] The 'Eagle Eye' represents both the precise accuracy of the laser sensor and also the backlit 'eye' peeking out under your palm. There's a choice of three colors depending on your preference between red, green and orange, which can be selected via a button in the base. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] Behind the mouse-wheel, there's an on-the-fly DPI change button, and up front the braided USB cable means even if you catch it under a chair wheel or desk leg, it won't break or stretch. Meanwhile its brushed aluminum looks great, feels good in the hand and is also easily cleaned after sweaty gaming sessions (yea, it happens!).
The USB cable is even labelled ROG, so when you're peeking around the back of your case you know which one it is straight away.
Popular Posts
The ROG Kithara just benched every other gaming headset I own
Just about everything I ask for in a premium gaming headset, the ROG Kithara does with gusto.
The ROG Raikiri II is my new go-to game controller — and I can’t put it down
I'm a PC gamer who plays on the couch — and the new ROG Raikiri II is the lynchpin of my living room battlestation.
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
