CES 2015: ROG Swift PG27AQ 27-inch 4K LCD With GSync
In 2014 ROG launched the critically acclaimed Swift PG278Q - a 27-inch WQHD (2560 x 1440) resolution 144Hz monitor with Nvidia G-Sync. At CES 2015, ROG is announcing the Swift PG27AQ - a 27-inch 4K (3840 x 2160) resolution, providing 2.25x the resolution (and equally, 2.25x greater pixel density) and Nvidia G-Sync that makes gaming with an Nvidia graphics card silky smooth.
Inside ROG packs its unique GamePlus crosshair overlays and timer functions, while outside it has an easy-to-navigate on-screen display (OSD) with a five-way navigation joystick and hotkey shortcuts, an ergonomic design with full tilt, swivel, pivot and height adjustment, and a smart cable-management system in a super narrow bezel design.
Do note that it's not a replacement for the current model and both PGs will exist side-by-side as top-tier gaming monitors, providing a choice to gamers looking at 27-inch displays; between the fast gaming 144Hz, WQHD/8-bit TN PG278Q and the higher 4K resolution, with in-plane switching (IPS spec) LCD in the PG28AQ .
Complete product details will be released at launch.
Announcement Spec:
- 27-inch LCD with super-thin bezel design and ROG aesthetics
- 4K (3840 x 2160) @ 60Hz
- In-Plane Switching spec LCD
- Nvidia G-Sync
- ASUS ROG GamePlus
- DisplayPort 1.2
- Contrast Ratio: 1000:1
- Brightness: 300 cd/m²
Quick FAQ
1) Does it have ULMB (Ultra Low Motion Blur) /3D vision support (since it’s not 120Hz)
Unfortunately these technologies are not available at 4K/60Hz.
2) Does the Swift PG27AQ support ASUS Eye Care?
Yes, the Swift PG27AQ has flicker-free, low-blue light and anti-glare technologies.
3) Why not 4K @ 144Hz?
Current DisplayPort bandwidth limits 4K resolution to 60Hz only, so, for fans of FPS/shooters, beat 'em ups and competitive RTS (for example), we still recommend the fast-refresh PG278Q, while gamers who play MMOs, RTS, MOBA, 4X, Sims or action/adventure (again, for example) will likely prefer the greater resolution, and still benefit from G-Sync.
Popular Posts
Gamers battle on ROG gear in upcoming ESPN EXP tournament series
ROG is powering up ESPN's new EXP esports tournament series with our GL12CX desktops, PG248Q monitors, and SCAR III laptops.
See ROG’s new gaming laptop displays at Computex: 4K120, 4K AMOLED, and 17” 240Hz
From insane speed to incredible detail, our latest laptops and technology demos showcase the best gaming laptop panels on the planet.
We're prepping for PAX East with swag, online tournaments, and special deals
The road to PAX East starts here. We're kicking off the party early with an online tournament. We've got swag, discounts, and PAX tickets up for grabs!
