The ROG Cronox ARGB gaming PC case stuns with an LCD screen, panoramic paneling, and more
Any cutting-edge gaming rig requires an incredible chassis. That case needs room for the biggest, best components. It must move air like a champ. And above all, it ought to dazzle, giving onlookers a reason to stop and drop their jaw. The ROG Cronox ARGB gaming PC case hits each note with verve, giving you one chassis to rule them all.
The ROG Cronox ARGB’s aluminum-trimmed frame will draw all eyes to your setup while its panoramic tempered glass panel displays your internal components. Its patented rotatable side fan bracket plays double duty, making it easy to install fans while letting you direct airflow right where it’s needed most. The case has room for all the latest, greatest PC hardware. It even packs a small, integrated 60 Hz LCD screen inside, giving you a wide canvas for personalizing your machine. Add up all these perks, and the ROG Cronox ARGB makes a strong case for being your next battlestation showstopper.
The ROG Cronox ARGB packs style for any setup
The ROG Cronox ARGB's aluminum-trimmed frame and precision-cut edges, along with subtle lighting touches, do a lot of aesthetic work. They deepen shadows, soften visual transitions, and make for a tasteful gamer chassis that sports ROG identity without insisting upon itself. The tall tempered glass panel puts your carefully selected components on center stage, and it curves seamlessly from side to front to give you an unhindered view of the action. Glow up your case's internals with RGB, go minimalist or stealthy, do whatever you want — your style will be the star of the show.
The interior’s hinged 9.2-inch 60 Hz LCD screen module gives you one more way to personalize your rig. The module pivots outward on a hinge so that you can get the perfect viewing angle. You can have it display a wide variety of imagery, from exclusive ROG animations and system monitoring information to custom content of your own design. Whether you want to display holiday greetings, notifications and reminders, a digital clock that stays on even when the system’s off, or a system dashboard with CPU, GPU, memory and chassis fan stats, you can have it. This LCD screen module even has a theme editor for showing off customizable backgrounds alongside system info, if you really want to tinker and make the module yours. It’s all up to you.
The case's size leaves ample room to trick out your chassis' interior however you like. It’ll accommodate dual 360 mm radiators without fuss. You can fit up to four 120mm fans across the bottom intake, in the side fan bracket, and up top, plus up to two fans in the rear. Support for graphics cards up to 400 mm and a 180 mm max CPU cooler height mean you can put just about anything in this case. The ROG Cronox ARGB is ready for EATX and BTF motherboards, so clean-build enthusiasts keen on a big rig can have it all. Check out our full slate of BTF components to see just how organized and visually cohesive your rig can get.
Remember, that includes graphics cards like the ROG Astral GeForce RTX 5090 BTF Edition, for those who dare. The ROG Cronox ARGB’s patented graphics card slot clamp makes it easy to simply and safely lock in a hefty GeForce RTX 5090 card. We’ve also just debuted a new mechanism for hooking up an AIO CPU liquid cooler that, like our new ROG Strix LC IV Series, doesn’t require you to figure out how to hide the cables connected to the pump housing. Click here to learn more.
Keep it cool with the ROG Cronox ARGB
The ROG Cronox ARGB comes with four pre-installed ROG Eurux GR120 ARGB fans and an ROG Strix XIN120 ARGB lighting panel, featuring a multi-layer mirror design that creates deep, cascading light layers, delivering a dynamic sense of motion and immersive visual depth. With additional space for more 120 mm fans, it lets you boost airflow for hardcore gaming. The patented rotatable side fan bracket gives you a flexible airflow channel tailored to your needs.
We recommend our new ROG Eurux GR120 ARGB case fans as the perfect companions for your ROG Cronox. These 120 mm fans feature liquid-crystal-polymer blades and deliver up to 2600 RPM, pushing as much as 85 CFM of airflow with 4.5 mm H₂O of static pressure — making them well suited for both case ventilation and radiator duty. In addition to standard fans, reverse-blade versions are also available, giving you greater flexibility for optimized airflow and cleaner aesthetics. Both single-pack and triple-pack options are offered to suit different build needs. Opt for a three-pack of the ROG Eurux GR120 ARGB fans and you’ll get a three-stage PWM controller, providing an easy and efficient way to switch between multiple operating modes.
Even under heavy loads, they keep noise in check, with sound levels topping out at 33 dB(A). Patented daisy-chain connectors simplify installation and cable management. With three individually addressable lighting zones per fan at our disposal, we were able to design some truly mesmerizing visual effects for these spinners. We can’t wait to see what you’ll come up with as you design your unique system.
The ROG Cronox ARGB: a tasteful centerpiece for your battlestation
With the room for today’s heftiest components and the style to shine in any PC gaming battlestation, the ROG Cronox ARGB is an easy choice for your next build. Whether you plan on making a big BTF rig or love the Cronox’s panoramic paneling and slick LCD screen, it’ll fit your gaming dreams and display them with pride. Pair it with ROG Eurux GR120 ARGB case fans for the ultimate power couple.
For information on the pricing and availability of the ROG Cronox ARGB case and ROG Eurux GR120 ARGB case fans in your region, please contact your local ASUS representative. And for a complete list of all the killer gaming gear ROG is delivering at CES 2026, check out this article.
Popular Post
What makes a good gaming laptop? Benchmarks don’t tell the whole story
How ROG Nebula uses ELMB for ultra‑sharp, blur‑free gaming
How does ROG keep its Zephyrus laptops cool when they're so thin?
The 2026 Zephyrus Duo lets you do it all with full-size dual screens
With room for today’s heftiest components and the style to shine in any setup, the ROG Cronox ARGB is an easy choice for your next build.
The ROG Strix Helios II is the gaming PC case for ambitious DIY builders and hardcore gamers alike
The ROG Strix Helios II is the ultimate desktop PC case for gamers who want a wealth of features and style.
How to make your gaming PC stand the test of time
A few tips and tricks to keep your system running smoothly for years to come.
