XMP problem!!
elopezam1
Hello I am new to the forum but I have read a lot about my problem in the forum and I think I have tried almost everything they have recommended in other cases similar to mine but without luck.
I start, I have 2x8gb ram trident z rgb 3466mhz, when I try to activate the profile xmp the screen turns off and the PC restarts does not get to boot, it only lets me enter the BIOS again to change the settings.
I have tried almost everything:
enter the values manually.
increase latencies
raise the ram voltage.
play with VCCIO and S.Agent voltage.
try lower frequencies
try with just a ram stick
My PC:
asus rog maximus x hero wifi-ac
8700k
corsair h115l
2x8gb g.skill trident rgb 3466mhz
1080ti aourus waterforce
sound blaster zxr
corsair rm850i
PS: the ram I use in slots 2 and 4 (with the LR I can not use slots 1 and 3)
Somebody help me please?
the pc is new and I am desperate.
my languaje is not english, sorry for that.
10 REPLIES 10
elopezam1
I add, I updated and I have the last bios.
Menthol
Level 14
elopezami,
Can you list the exact memory kit, are you overclocking your CPU, cache? What bios settings have you changed from default?
My personnel experience with a Corsair 3466 mhz memory kit on Maximus IX was I could run the memory kit at 3200 mhz but could never get 3466 stable for daily use
Menthol wrote:
elopezami,
the memory kit:
https://www.amazon.es/gp/product/B01N6SJGG6/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
my cpu is stock, all at default bios settings.
elopezam1 wrote:
the memory kit:
my bios settings.
https://drive.google.com/drive/folders/1WptLHrf8lNz51_ATZxfV7rbIPb5xGzzf?usp=sharing
I miss something that I have to activate or something
uppp
Menthol
Level 14
Could you try setting AI overclock Tuner to XMP click yes when it asks then manually set memory speed to 3200 and see if it will boot and run a stability app
not work...
I have ordered new units, on Monday I will see if the new rams solve the problem.
the problem persist.
