Results 1 to 8 of 8
    ROG Junior Member Array giblol PC Specs
    giblol PC Specs
    MotherboardROG Maximus XI Gene 602
    Processor9900K
    Memory (part number)F4-4500C19D-16GTZ
    Graphics Card #1Nvidia 2080 TI FE 380 BIOS
    MonitorASUS PG258Q 240Hz
    CPU CoolerCPU Loop: Dual 360 60mm PP Dual D5 GFX: 480 45mm PP D5
    CaseTT LVL20XT
    Power SupplyCorsair AX1200i
    Jul 2017
    4
    After advice on 1.4v+ overclocking
    Long time overclocker, forever lurker.
    Ive had this rig for about 9 months, Basicly Its been running stable 5.05Ghz @ 1.32v for 9 months. Today I updated the bios, pushed all cores to 51 (5.25Ghz BCLK 103.25 for 4266 mem) @ adaptive 1.37v, XMP Working, LL6, cache 46, vccio and agent auto (hahaha) no issues booting, just passed 4 hour realbench with no AVX offset and 8 hours on P95 no issues. Max temp was 78 degrees according to realbench.
    My question is where do I stop? Any other settings in the BIOS you recommend playing with? I really have not changed much. I did not even have to play around to XMP working.
    To go one ratio higher I will need to break 1.4v which I understand is the safe limit.
    Mess with the BCLK? Keep going to 52? Bin it and upgrade to z370?
    Rig:
    Asus M9A with Monoblock
    7700K delided
    2 x 8Gb Gskill 4266Mhz b-die (XMP timings) ROG mode 2 1.4v
    1500w PSU
    420mmx45mm rad
    360mmx60mm rad
    120mmx60mm rad
    Dual D5, 1L res.
    18 Corsair ML fans
    Cheers
    Nate152 PC Specs
    Memory (part number)Kingston HyperX Predator 16GB 3000MHz 15-15-15-35-1T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    302
    16,319
    Hi giblol
    With those temps it looks like you delidded your 7700k and you have a good overclocking one.
    Here is my delidded 7700k at 5.2GHz with 1.44v
    Click the pic to make it bigger
    giblol PC Specs
    Processor9900K
    CaseTT LVL20XT
    Jul 2017
    4
    Probably should mention it was 40+ degrees outside when I was benching it, no ac inside . I was wary of 1.4v after my initial research, keeping balanced power settings in windows and adaptive voltage should not harm it that much???
    Tempted to BLCK tweak, the extra pcie bus speed couldn't hurt the 1080 ti...
    Might go big and feed 1.5v to the RAM and see how high I can get with BCLK. SPD>Timings for what i am using it for anyway. Keep ideas comming.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    302
    16,319
    The BCLK overclocks pretty high on z270 but it doesn't seem to benefit much.
    Here's watchdogs 2 at 5.3GHz, cache at 5.0GHz with 1.52v and the BCLK at 312.50
    The Bus Clock is the BCLK
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,546
    1.4 volts vcore is fine with your cooling setup, I would not exceed 1.45, check Silicon Lottery for the voltage needed on there binned 5.2GHZ chip and see if that is stable for you, I personally would not use much higher for daily use. as for memory there is the Raja 4133 @ 1.4 volt preset in the bios that gives better performance with tighter timings than 4266 and XMP timings, VCCIO and VCCSA on auto typically runs a higher voltage on these rails than may be required, this is where manually tuning these voltages comes into play, by lowering voltages lowers temperatures and can improve stability, higher voltage is not always better here
    Overclocking blck on modern Intel platforms gives no gains compared to using multiplier and is only required for certain memory speeds, it may or may not affect your GPU but also can negatively affect NVME drive speeds, USB device speeds and functionality, even network speeds can see a negative reaction to blck overclocking
    giblol PC Specs
    Processor9900K
    CaseTT LVL20XT
    Jul 2017
    4
    ok, played a little.
    5.3 @ 1.42 stable for 2 hours of pubg but might test some more.
    BLCK 105, after advice on negative impacts I went from 204 back to 105 (1.75oc)
    Interstingly RAM stable at 4360 with XMP @ 1.45v
    Cache at 5Ghz.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    302
    16,319
    Wow that is awesome giblol, you have a golden 7700k and is one of the highest overclocks on a 7700k I've seen.
    My 7700k at 5.3GHz with 1.52v could play games but could not pass a stress test and before delidding, I could not boot to windows at 5.3GHz.
    Now to overclock your 1080 Ti's, you should see a 10 - 20 FPS increase and at 1080p probably more.
    I'm not sure if you're aware but you can game at 4k resolution (3840 x 2160) using the DSR Factors setting in the Nvidia Control Panel.
  8. #8
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,546
    1080ti and gaming below 4K, deplorable
