Results 1 to 6 of 6
02-21-2018 10:01 PM #1
- Join Date
- Feb 2016
- Reputation
- 10
- Posts
- 11
AI SUITE 3 not working (ASUS RAMPAGE V EXTREME)
When I try to access most features in AI Suite 3 I get the error:
"Access violation at address 07024B6B in module 'dip4.dll'.
Read of address 00000330"
It also gives an error on startup, something like "Name Unknown".
Dual Intelligent Processors 5 is version 1.05.13
I'm on Windows 10 64bit
02-22-2018 02:51 AM #2
RavageSoul PC Specs Motherboard Asus Rampage V Extreme Processor i7 5930k Memory (part number) G.Skill Ripjaws F4-2800C16Q-16GRk Graphics Card #1 R9 Fury X Monitor Asus VG248 144hz Storage #1 Plextor M.2 120gb Storage #2 WD 1TB HDD CPU Cooler CM Nepton 280L Case Corsair 760T Power Supply CM V1200 Platinum Keyboard Corsair k70 Mouse Asus Spatha Mouse Pad ROG pad OS Win 10 64bits Network Router Asus RT-AC5300
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 4
my ai suite runs well, but i can't control my fans, any one know if i can install the ai suite from the newest Rampage mobo?
02-22-2018 03:42 AM #3
- Join Date
- May 2015
- Reputation
- 10
- Posts
- 9
If you go to Asus Support for your motherboard , download and install the newest version of the complete AI Suite. Then download and install The new DIP 5 that should be on the download section for your motherboard.
I am sure that you will find everything to work correctly. DIP 4 has been superseded by Dip 5 just in the last week because of Windows 10 update.
Good luck
02-23-2018 10:45 AM #4
mikex999 PC Specs Motherboard Asus Z370 F-Gaming Processor i7 8700k Memory (part number) CMK16GX4M2E4000C19R Graphics Card #1 Zotac 1080 Amp! Extreme Monitor Dell S2716DG Storage #1 Samsung 970 evo 512gb Storage #2 Samsung 950pro 256 CPU Cooler Corsair H150i Pro Case Fractal Design Define TG Power Supply Be quiet straight power 750w Keyboard Corsair K70 Platinum Rapidfire Mouse Corsair Vengeance m95 OS Windows 10 Network Router Asus RT AC88U
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 40
this ai suite is really dogsht. Can 't understand why asus made great hardware but crap software
02-23-2018 09:17 PM #5
- Join Date
- Feb 2016
- Reputation
- 10
- Posts
- 11
When launching Setup.exe in "AI_Suite_III_3.00.13_DIP5_1.05.13" it gives error message twice saying "CreateProcess failed (193)" before opening the DIP5 installer.
The issue started after upgrading, I was running an 1-2 year old version without issue earlier.
11-17-2020 02:41 AM #6
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 33
