Results 1 to 4 of 4
    New ROGer Array
    Feb 2018
    2
    Cool Asus 1080Ti Poseidon prepare to be quite shocked (or how to drop temps by ~15°C)
    I found that modern heavy cards tend to bend down on standard ATX tower setups because of their increased over standard weight.
    ASUS Poseidon 1080Ti is a very heavy card (water block + air heatsink). After some time it bends a little losing good contact with PCB/GPU and has ~50°C. Bend is so subtle you'll barely notice it. You have to lift card while in the benchmark to test it.
    What you want to do is lift a card at the most distant part from a PCI-E slot (plastic next to power cords). Do NOT lift PCB - always lift heatsink/water block and be delicate. I lifted plastic with LEDs next to power plugs with a plastic stick.
    I clocked mine at GPU@2126 1075v MEM@12650
    Have Fun!
    p.s. It can apply to any modern GPU if it's water-block or not - I can't test it. It's very subtle bend but can be very big temp improvement. Remember air cooled cards are less efficient in cooling so you have to wait much longer to see temps drop after lifting the card. With water block, it's almost instantaneous.
    ROG Member Array Tbolt214th PC Specs
    Tbolt214th PC Specs
    Laptop (Model)Asus G73-JW, MBPr 15"
    MotherboardAsus ROG Strix Z370-E Gaming
    Processori7-8700k
    Memory (part number)CMK32GX4M4B3600C16
    Graphics Card #1Asus Poseidon GTX-1080-Ti
    Graphics Card #2Asus Poseidon GTX-980
    MonitorAsus PG278B
    Storage #12x Samsung 850 Pro + 1x 960 Evo 250GB
    Storage #2Seagate 2TB HDD 2x
    CPU CoolerWatercool Heatkiller-IV @ MoRa3-360
    CaseCorsair Carbide 500r
    Power SupplyCorsair AXi 1200
    Keyboard Logitech K520
    Mouse Logitech G700
    Headset Logitech
    OS Win10 Pro AMD64
    Network RouterAVM Fritz!Box 7490
    Accessory #1 Oculus Rift
    Accessory #2 TM Hotas, Saitek Combat Rudders
    Accessory #3 Track-IR 5 Pro
    Feb 2017
    16
    100% true, what a drop in temp
    I checked what you said...and OMG, from 50-51°C I dropped to 38°C under full load ming.
    All it needed was a support stick to lift/support the card.
    I own 2 of them, I need to check the other one ( older 980GTX Poseidon ) if that card has the same symptom.
    Asus needs to address this !!! For a 1.199€ card this is a NoGo !
    It resides in an Asus Z370 ROG Strix Gaming-E board btw.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Many recent premium motherboards (including ROG and STRIX gaming mobos) come with reinforced PCIe slots. There's many GPU card braces/supports available. Some PC cases (at least the better gamer-centric ones) have GPU card support structures (or accessories) built in.
    ASUS has addressed this on mobo PCIe slots. The rest is up to chassis manufacturers and aftermarket/modding vendors.
    [/Korth]
    Tbolt214th PC Specs
    Processori7-8700k
    MonitorAsus PG278B
    Mouse Logitech G700
    Headset Logitech
    OS Win10 Pro AMD64
    Feb 2017
    16
    Strange enough that this happens and that there is no info about the needed support, a short note as a Flyer in the box would help, a Guide or something.
    The reviews I habe read also measure the cards with those far too high temps, anything over 47°C is obsolete. That's the max tgemp I can get that card to when I am at 2101 and 12500 MHz, the reviews I have read where all around 50°C with less overclock.
    I am aware of the general problematic and I doubt there is enough consensus among the board who defines the PCIe standards, the board manufacturer and the case designers and last but not least, the customer who wants to put all this together.
    As Asus is the one held responsible if the card doesnt perform as it should, it would be nice if they would make this topic somewhat more public, more awareness
    of how cards are stressed and overheated due to the way they are laid out and mounted.
    I yet have to test if the support stick is NOT needed when the card is mounted perpendicular to G Force, aka flat board with card upright. If it still goes 50ish °C
    then the reason is not enough pressure on the block to the GPU die. I will test that once I have the chance.
