Results 1 to 4 of 4
02-25-2018 06:24 PM #1
computerhead2 PC Specs Motherboard Maximus VIII Hero Processor 6700K Memory (part number) F4-3200C16D-8GTZ Graphics Card #1 EVGA GTX 970SSC OS Windows 7
- Join Date
- Mar 2016
- Reputation
- 10
- Posts
- 7
First Time Power Up - No POST - Q-Code 00 - Bad Board or CPU?
The CPU is an 8700K, the board is the Maximus X Hero WI-FI AC.
With power applied The board LEDs light up and color cycles. But the CPU fan does not power up/spin. The cases fans do come on.
I get no beeps, or codes other than 00 (not used), just case fans and board LED lights
I have moved RAM (2 sticks ) to different slots in accordance with the User guide directions. The memory has is GSKILL RGB and the modules LED come on and color cylcle
I just used the FlashBack Bios via the USB and that seemed to work okay, based on the flashing blue button and the time (2 -3 minutes). So my current BIOS should be 1003
I have checked all the power connections and removed the CPU and inspected for any bent pins in the socket and reinstalled its and have the air cooler installed (NH15S).
I don't have a graphics card installed , I am not using a SATA port, instead have a M.2 SSD drive installed
Thinking it is the CPU, but maybe I have missed something... any thoughts/recommendation or advice to furthur trouble shoot?
Thanks
Chuck
02-26-2018 01:14 AM #2
Things to check:
1) Although your post states you've checked the power connections, double-check the EPS 12V connector, again. If it is a modular PSU, check it it secure on both sides (PSU connector and motherboard connector).
2) If the board is in a chassis, take it out set it up on a non-conductive surface - just in case it is shorting or being warped.
3) If those don't work, difficult to say whether it's the CPU or board. Code 00 can be numerous things on the board (such as power rails not pulling up or corrupt firmware). Could be CPU, too, but unlikely if it is new (not something we hear of often).
-Raja
05-30-2018 01:47 PM #3
- Join Date
- May 2018
- Reputation
- 10
- Posts
- 1
Same issue!
06-08-2018 08:06 AM #4
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 3
same issues
Hello,
i am a nearly the same, for me it was the CPU was installed incorrectly.
once i saw this, changed CPU, it worked fine
Hope that helps
tim
