Results 1 to 5 of 5
    ROG Guru: Yellow Belt Array Marko911 PC Specs
    Marko911 PC Specs
    MotherboardAsus Rampage extreme VI
    Processori9 7900x @4,7Ghz cores at from 7x1,20v-3x1,21v
    Memory (part number)G.skill 32GB 3200MHZ CL14 DDR4 quad kit
    Graphics Card #1Aorus 1080ti extreme edition @2032Mhz/12000Mhz
    MonitorAsus something IPS,144Hz ,Freesync
    Storage #1m.2 Samsung EVO 960 1TB
    Storage #2m.2 Samsung EVO 960 500GB
    CPU CoolerEKWB monoblock
    CaseThermaltake view 71 TG
    Power SupplyCorsair RM1000i
    Keyboard rappo wireless keyboard and mouse
    Headset Logitech G933
    OS win 10 pro/64bit
    Accessory #1 HL GTS 360mm/push only
    Accessory #2 HL SR2 360mm push/pull
    Accessory #3 HL SR2 420mm push/pull
    Marko911's Avatar
    Dec 2017
    141
    4x140mm exhaust fans vs 12x120mm intake fans?
    Hi there,I'm in process of updating my x299 build,and I plan on installing third rad in my tt view 71 TG case.And I was planning on top to have 6x140mm exhaust in push/pull and rear 140mm exhaust fans and in front and side 360mm rad in intake push/pull fan config.All fans are NZXT aer RGB.(paid 300eur for them,can't throw them away)
    Is this in your opinion good configuration?
    Any pro and cons for this config?
    Thanks in advance for your help.
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,128
    try and have a balanced airflow in the case.
    is the best i can advice.
    ROG Member Array j-d0gg PC Specs
    j-d0gg PC Specs
    MotherboardZenith Extreme
    Processor1950x
    Memory (part number)Corsair Vengeance 32gb 4x8
    Graphics Card #1R9 290x
    CPU CoolerEnermax TR360
    Case90s ATX
    Power SupplyRM1000 Corsair
    Keyboard IBM Model M
    OS Win 10 Pro
    j-d0gg's Avatar
    Dec 2017
    14
    two big things
    positive case pressure goes a long way, you want more air coming in than what's going out
    more fans doesn't necessarily equal more cooling, Linustechtips covered this pretty well in the Blowymatron episode (lol) essentially, a heatsink with more surface area and a normal fan will be as effective or more effective than just pushing more air over a smaller heatsink.
    so, naturally a 3x 120 radiator is going to mop the floor with 1x 120 with a big fan on it. my advice, is the 6x 140s are going to in fact push more air than the 360 setup but how much material and how thick is that radiator on those things, and what material is it? Copper radiators are the king in heat dispersion.
    Also with extra air you begin to approach the law of diminishing returns, past a certain point you just won't gain much. A bad ass radiator, made of copper with 3x 120mm pullers will perform just as well as a cheap aluminum radiator with 6 Blowymatron 186cfm push-pulls. My Threadripper cranked to the moon at 4.2ghz struggles to get above 50*C load with the same Liqtech cooler you have but I have the TR360 model and with the three pullers on the inside of the case it can provide 500w of heat dissipation by itself with the stock fans.
    All those fans mean nothing if they're pulling it hot air too, my radiator is on the front of the case and away from other heat-generating sources. Throwing more fans at it doesn't necessarily mean better temperatures.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    I'm always apprehensive about fans sucking intake across a rad, very suboptimal, but sometimes we all do what we gotta do to get those rads mounted.
    ~16 fans placed everywhere is a very much more noise for very little cooling advantage over ~8 fans placed where they're needed.
    That much spinning airflow might cause recirculation or dead air zones which trap heat pockets in various corners, sometimes less is more.
    Aggressive airflow, depending on the fans either a positive-pressure or negative-pressure system (not a neutral-pressure system), either way a lot of dust and stuff will get sucked into the chassis, the only question is whether it'll build up in all the little chassis vents or whether it'll clog up the fans. I'm all for promoting airflow, but as pointed out above, increased airflow hits a point of diminishing returns while increased airflow only increases ingress of airborne gunk you don't want in the chassis.
    [/Korth]
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,670
    Marko911...by my count that's 7 140 vs 12 120...however the push pull thing is way overrated so we'll just go with cross sectional area.
    140x140x4=78400
    120x120x6=86400
    So you only have 10% more area as intake than exhaust...slight positive pressure...all good
    Placement...sounds OK to me...front and side intake...flow over GPU...to exhaust top and rear...
    Anyway....please watch this and get edumacated...the MOAR FANS THE BETAH!
Tags for this Thread
