Results 1 to 5 of 5
    ROG Member Array
    Jan 2018
    5
    ROG strix impact - sensitivity problem
    So i have a few of these and they are great but there is one slight problem that persists with all of them.
    Basically while i am playing my sensitivity will change momentarily and obviously makes aiming in that moment difficult, it's quite annoying. I also noticed that rocketjumpninja(youtuber) noted a similar problem in his review. I don't know if it is surface dependent but i'm using a steelseries dex mouse pad if that helps.
    Is this issue going to be fixed with a firmware update?
    It's the only thing holding this mouse back, oh and the mouse feet are terrible but i just replaced them.
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    96
    1,492
    Can you verify if this occurs in Armoury II?
    https://rog.asus.com/forum/showthrea...ny-issues-here
    ROG Member Array
    Jan 2018
    5
    Quote Originally Posted by MasterC@ASUS View Post
    I will let you know, it's unpredictable .
    ROG Member Array
    Jan 2018
    5
    Nope still happens, i knew it would, not a software thing, seems like a sensor implementation thing.
    ROG Member Array
    Jan 2018
    5
    hmm i maye have been wrong, i was in an awkward spot when i tested it yesterday. COuld have been my awkwardness may have tilted the mouse or something.
    But i just had a really long gaming session and it didn't happen once, though that has happened before.
    How would a software update solve such an issue anyways?
