Results 1 to 9 of 9
    ROG Guru: Yellow Belt Array R5Eandme PC Specs
    R5Eandme PC Specs
    MotherboardRampage V Extreme/U3.1
    Processori7-5930K
    Memory (part number)Corsair Vengeance LPX CMK64GX4M8A2400C14
    Graphics Card #1MSI Geforce GTX 980Ti
    Sound CardAsus Essence STX II
    MonitorAcer B286HK 4K UHD
    Storage #1Samsung 960 Pro 1TB NVMe
    Storage #2Samsung 850 Pro 1TB SSD
    CPU CoolerNoctua NH-D15S
    CaseCooler Master HAF 932
    Power SupplyThermaltake TPG-1200M-F 1200W
    Keyboard Corsair K70 Cherry MX Brown
    Mouse Asus Sica
    Mouse Pad "And God said ... <Maxwell's equations> ... and there was light."
    OS Win 10 x64 Pro
    Accessory #1 Asus USB 3.1 A, StarTech USB 3.1 C PCIe adapters
    Accessory #2 Syba 1394A/B Firewire PCIe adapter PEX30009
    Accessory #3 Asus OC Panel I
    R5Eandme's Avatar
    Jun 2017
    58
    244
    Does OC Panel report Ryzen 1700X/1800X temps accurately, or with a +20 C offset?
    I read that Ryzen 7 1700X and 1800X CPUs appear to add about a +20 C offset to the actual temps at the Tctl sensor (die-to-heat spreader junction). AMD purposely does this so the fan control curves will act more aggressively to get out in front of rising CPU temps in response to increased processor demands. But this has freaked out users who see high temps at idle (e.g. 40-50 C) through software monitoring. This is my understanding of the situation so please correct me or add to the post with additional info.
    My question: is anyone using OC Panel I or II on a build with Ryzen 7 1700X and 1800X CPUs, and what temps does OC Panel show? Are they accurate (i.e. no 20 C offset)?
    Thanks!
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,380
    It's a 27 degree offset...so yes Tctl can look shocking. 95 degrees Tctl equates to 68 degrees Tdie which is suggested max. Some software applies the offset some does not I guess.
    I don't have an OC panel..can't help with that bit
    R5Eandme PC Specs
    Processori7-5930K
    Mouse Asus Sica
    OS Win 10 x64 Pro
    R5Eandme's Avatar
    Jun 2017
    58
    244
    Quote Originally Posted by Arne Saknussemm View Post
    Thanks Arne,
    Do you happen to know which sensor ASUS BIOS uses, Tctl or Tdie, and if the BIOS also might apply the offset?
    On my R5E, I noticed that OC Panel worked fine to report CPU temps and CPU fan rpm even before installing an OS. So OC Panel must be seeing what BIOS sees, at least on that platform.
    This situation is confusing. especially to me.
    Apr 2012
    481
    13,380
    Sorry R5Eandme....I'm telling you wrong...the problem is I haven't fired up one of those boards...I'm talking Threadripper offset...you are correct...for ryzen it is 20 degrees
    But it's more or less the same deal I guess...here, latest BIOS do the offset thing and report actual temp...so on my MB display it shows idle temps at 23 dgrees...and same in BIOS...I would presume latest Ryzen board BIOS would do the same...
    But you know...presumption is the mother of...
    gupsterg will know...
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    76
    807
    You guys are correct it will be +20°C on TCTL for 1700X/1800X . Most software monitoring now accounts for it. Some opt to show TCTL and another reading without.
Name:	RB 4.0 1.375V 3333F 1.018V 1.375V 60 30 30 30 30 during 1.5hrs 22C.jpg
    I believe OC panel will show the CPU temperature from Super IO chip (green box). As it hooks into UEFI/BIOS and that is what is shown in UEFI/BIOS "hardware monitor". Initially at launch there were some oddities with this reading, but ~3-6mths in it was all sorted.
    Some still are freaked by the sporadic jumps Ryzen exhibits for CPU temps. This is as the CPU has ~20 on die sensors and some rotating goes on plus highest value shown.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme - G.Skill Trident Z 3200MHz C14 QC - RX VEGA 64
    R7 2700X - Custom WC - Asus Crosshair VII Hero - G.Skill Ripjaws V 3200MHz C14 DC - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    R5Eandme PC Specs
    Processori7-5930K
    Mouse Asus Sica
    OS Win 10 x64 Pro
    R5Eandme's Avatar
    Jun 2017
    58
    244
    Thanks Gupsterg and Arne! I appreciate this difficult to find information. What a great forum.
    I looked up "Super I/O chip" on Wikipedia and learned some new things. It apparently interfaces with the UEFI BIOS chip, temp sensors, fan PWM and so on. The fog lifts a little. I am guessing it also participates in the boot process, like maybe writing BIOS into memory? Is this the "System on Chip" or SOC that I've heard about?
  7. #7
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    76
    807
    NP .
    The info in this article should cover SOC aspect of Ryzen, link.
    The Super IO chip does not write BIOS to memory, it is doing other functionality AFAIK (temp sensors, fan PWM, etc). It does interface with CPU via LPC bus. Only block diagram I could find with relevant stuff was a Gigabyte X399 one .
    I'm gonna have to find an ASUS priest to confess my sins now! .
  8. #8
    R5Eandme PC Specs
    Processori7-5930K
    Mouse Asus Sica
    OS Win 10 x64 Pro
    R5Eandme's Avatar
    Jun 2017
    58
    244
    " I'm gonna have to find an ASUS priest to confess my sins now! ."
    ... and afterwards say a few Hail Mary's (especially while flashing BIOS).
    Thanks so much, this is very informative, even if it is Gigabyte.
  9. #9
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    76
    807
    LOL, even the divine may not forgive my sins! .
    NP , now you'll get your googlefu in gear some more .
