Request Help With 10G NIC On Extreme VI
AR-12
Hi everyone,
I am having a problem with getting my 10G NIC on my Extreme VI motherboard to work with Windows.
As a start, I am running Windows 10 (1703), and have both the Intel & 10G NICs enabled in the BIOS (latest BIOS). Windows 10 Device Manager recognizes the Intel NIC just fine; but no 10G adapter shows up. There is a "Ethernet Controller" listed under Other Devices, but it has a yellow question mark. Even after I install the 10G LAN drivers from the ASUS site, nothing changes.
As a note, I also run the machine as a Hackintosh, and OSX recognizes the 10G NIC just fine --- it functions perfectly under High Sierra. Thus, I know that this is not a hardware problem.
So, can any of you guys help me figure out what I need to do in order to get the 10G NIC working under Windows 10? I would really appreciate any help.
Thanks in advance.
14 REPLIES 14
BigJob
IS your lan cable attached to the lan port of the nic card?
yes
BigJob wrote:
Download the LAN & wireless drivers off of here, https://www.asus.com/us/Motherboards/ROG-RAMPAGE-VI-EXTREME/HelpDesk_Download/
And download this https://s3-us-west-1.amazonaws.com/aquantia-staging/wp-content/uploads/2018/02/Aquantia_AQtion_Win_v...
Ref link https://www.aquantia.com/driver-download/ > Part Number: Aquantia AQC-107 10G
https://www.asus.com/us/Motherboards/ROG-RAMPAGE-VI-EXTREME/specifications/
Thanks for the links -- I've already tried these, and no difference.
Interestingly, I have also tried the ASUS 10G LAN card, and I cannot get that to work either (in Windows; with OSX, it works perfectly).
BigJob
SO you downloadeded these drivers too or which asus 10g lan card were you referring to? https://www.asus.com/Motherboard-Accessory/ROG-AREION-10G/HelpDesk_Download/
baffled that the Aquantia AQC-107 10G drivers didn't fix the issue.
I have the 10G working n Windows 10. I have installed the Aquantis drivers two ways. One is Windows update has them. Two from ASUS website. Both worked fine for me. I am running Windows 10 Pro Version 1709 Build 16229.248. I do not have the 1GB Nic enabled. Try disabling it in the BIOS and see. BTW the cables doesn't have to be connected to install the driver and or see the device working properly in Device Manager.
So, I got the ASUS C100C 10G board working in Windows --- and then it abruptly stopped working. Windows no longer recognizes it at all. I keep wondering if I should just junk this motherboard, but the C100C continues to function perfectly under OSX High Sierra on the Hackintosh side --- so again, I do not believe this to be a motherboard issue. Guess I am just out of ideas with this.
BigJob
My next steps to try :
0) Reinstall all the drivers
1) Windows update to see if anything comes up
2) Device Manager > Add New Hardware > Manually try and add the C100C
3) Contact Windows Support via Live Chat & see if there's any thing else they can do
Very strange.
PoTski
I have the same issue. I cant se the 10gb nic at all.
Even when i enable the PXE Rom in bios there is no 10gb PXE boot option avalible or ROM post.
I have tried multiple BIOS versions and resets of the bios.
I think the Aquantia chip on my mobo is dead or something.
Could someone else confirm that the pxe rom posts on the 10g nic?
