03-03-2018 02:00 AM - last edited 3 weeks ago by ROGBot
03-03-2018 02:07 AM
03-03-2018 02:38 AM
JustinThyme wrote:
Full system specs please....
The nature of a thermal diode is to fail open. In laymans terms....they work or they dont. Accuracy is dependent on the source.
03-05-2018 07:47 AM
woppy101 wrote:
1920x @4ghz
X399 Strix
EVGA 1080ti
32gb LPX 3200mhz @3200mhz
Custom loop*
03-05-2018 09:47 AM
Arne Saknussemm wrote:*no mate I haven’t tried P-state overclocking because I’m not quite sure how to do it*
Hey woppy101...
Can I just ask if you have tried a P-State overclock on your CPU...and if you have...does it downclock and downvolt?
I set P-State here and the CPU downclocks but does not downvolt at idle
My RB stress test temps here https://rog.asus.com/forum/showthread.php?99129-Goodbye-Intel-hello-AMD/page10#post706336...I guess having the system out in the fresh air on a test bench helps...VRM doesn't go above 40:)
03-03-2018 02:13 AM
03-03-2018 02:28 AM
What is your ambient temp and is your MB in a case and does it have any VRM cooling apart from the onboard heatsink fan?
The PCH is the chipset...under the heatsink with the M2 slot nest to SATA ports
03-03-2018 02:44 AM
woppy101 wrote:
my ambient temp is between 22-24c, my motherboard is in quite a large case and has no additional VRM cooling but I do have a triple rad directly above the VRM heatsink pushing air out of the case, which I presume is pulling air over the heatsink.*
03-03-2018 02:58 AM
OK so yeah, more or less sounds normal to me 🙂
03-03-2018 01:37 PM
woppy101 wrote:
happy with that then, I just thought they would be much higher considering how much juice I’m giving the chip*
