Results 1 to 4 of 4
Thread: Thermal issue?
    ROG Member Array MatthewG PC Specs
    MatthewG PC Specs
    MotherboardAsus Maximus Ranger Z170
    ProcessorIntel I7 6700K Skylake
    Memory (part number)16GB Vengeance Pro DDR4
    Graphics Card #1GTX 1080 TI Strix OC
    MonitorROG Swift 27 2560-1440 TN G-Sync 144Hz- 165Hz OC
    Storage #1420GB HyperX Savage
    Storage #21TB Western Digital Black Performance
    CPU CoolerH100I GTX
    CaseNZXT 660 Mat Black Window
    Power SupplyRM850I
    Keyboard Razer Blackwidow Chroma
    Mouse Razer Deathadder Chorma
    Headset Hype X Cloud
    Mouse Pad Corsair - MM300
    Headset/Speakers Hyper X Cloud
    OS Windows 10 64 Bit
    Network RouterTP-Link W9980 VDSL2
    Feb 2016
    8
    Thermal issue?
    I am running a 6700k at 4.2ghz 1.20v adaptive.
    Idle
    CPU 25
    Coolant 28
    Stress Test RealBeanch 1 hour
    CPU 74c
    Coolant 40.1c
    Stress Test Without Filters 1 Hour
    CPU 71c
    Coolant 37.5c
    I am running a H100I GTX with 2x Akasa Piranha 1900RRPM
    They are pushing air up through the radiator and out the case.
    I am not sure whether to keep the filters on
    ROG Guru: Brown Belt Array meankeys PC Specs
    meankeys PC Specs
    MotherboardRampage VI Apex / Maximus IX APEX / Rampage V EX V10
    Processor7920X / 5960X / 6950X / 7700K
    Memory (part number)G.Skill Trident Z - 16GB
    Graphics Card #1Zotac 1080 Ti
    Graphics Card #2Zotac 1080 Ti
    Graphics Card #3ASUS STRIX GTX 1080 OC
    Monitor3 X ASUS V248Q
    Storage #1Samsung 950 Pro
    CPU CoolerCool Express SS
    Power SupplyThermaltake Tough Power Grand 1200W
    Keyboard Cyberus
    Headset Tittan
    OS Win 7 64bit
    Network RouterASUS
    meankeys's Avatar
    Apr 2013
    104
    1,553
    I would pull the cooler air in and push the hot air out. those temps dont seem that bad.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    So the difference is 3C? Doesn't sound too bad. It all comes down to whether you want to keep dust out of your system.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    Dust filters on all air intakes.
    I like that black foam air filter stuff (used in air ducts, air conditioners, microphone windscreens, high-end speakers, etc). It's cheap and common and easy to cut to size. It can be vacuumed, blasted with compressed air, rinsed under running water, thrown into a dishwasher or laundry machine, immersed in soapy detergent stuff for squishy spongy scrubbing. It's even handy for wiping up dust from other surfaces, lol. And it's black, which always looks cool in gaming hardware. Win-win-win!
    A positive-pressure chassis needs these filters on the fan intakes. A negative-pressure chassis needs these filter pads stuffed or lined into all the little vents and holes and gaps and crevices where inflow occurs - especially any bottom fan vents and "floor" level air holes.
    Small upside is that this stuff slightly muffles noise. Mostly fan noise, but some other things inside the chassis can make noise too. And it's wonderful at completely neutralizing "rattling" or vibrational noises caused by the chassis panels themselves. It's not full soundproofing "silent PC" stuff, but it sure helps cut down noise when put in front of the fans making the noise (especially when those fans are basically all directly facing the user).
    Small downside is that this stuff slightly reduces airflow pressure. Not volume, pressure. So unsuitable for rads (which need strong fans and even push-pull fans to move air across them) ... although intake across rads is always suboptimal and exhaust across rads shouldn't want to capture dust inside the chassis, lol.
    Increasing thickness increases these effects.
    [/Korth]
