Results 1 to 10 of 14
03-06-2018 05:44 AM #1
8700k overclocking and my cinebench score - where to go from here?
Attained a 1602 score at 5.0Ghz (1.290v). Ram is stock at 2133Mhz (16gb) because my system doesn't like the XMP configuration (go figure). AVX offset is set to 3. I basically followed der8auer's guide and everything is rock solid.
* https://imgur.com/a/EaJZW
* https://valid.x86.fr/g93j8w - CPUZ validator.
I don't really like the temps I'm getting running IBT and Realbench (mid 70's on avg) so I'll likely dial the OC down. I just needed to see what my CPU was capable of whilst not delidding on an AIO 280mm. Moreover, my case (enthoo evolv atx) isn't really ideal for airflow.. I'm just thankful I reside in an area where it doesn't get that hot during this time of year.
So the question is, should I delid even If I have absolutely no experience in this? Or should I dial the OC down?
Some other questions -
1. Now that I hit a stable clock, can I re-enable cpu svid support or should I leave it disabled?
2. Regarding my motherboard temp reading in HWiNFO64, temp2 is showing 56c and PCH is 50c - is that normal? Is my disabling SVID support conflicting and giving me wrong readings here? Sorry for being ignorant, I'm rather new at overclocking.
Thanks for your help!
03-07-2018 04:56 PM #2
Crickets. Nice to know this board can be so helpful
03-07-2018 05:07 PM #3
jpmboy PC Specs Motherboard Rampage VI Apex Processor 7980XE Memory (part number) G.SKill 3600c15 (2x)2x8GB Graphics Card #1 Titan V Graphics Card #2 Titan V Monitor ROG PG278Q Storage #1 Intel 900P Storage #2 4TB Raid 10 CPU Cooler Custom Water Power Supply AX1500i Keyboard Ducky Mouse ROG Spatha Headset Ultimate Ears Custom IEMs OS Win 10/Win7 Pro
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 118
1. whether or not you enable CPU SVID depends on the voltage control method you used. Setting this to Auto is best since it works with manual override or adaptive/offset.
2. You need air flow over the PCH heatsink. CPu SVID will have no impact on the on-board DTS reports (temperature)
3. 8700K does best delidded, but even at stock the IPC is so good the performance is "very snappy".
4. leaving ram at default will dampen performance significantly.
Get additional help here: http://www.overclock.net/forum/6-int...rt-thread.html
03-07-2018 05:09 PM #4
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,682
Stress tests are, of course the hardest thing you'll run on your CPU normally. So, if you are mid 70s at 5.0 I'd say that was OK....for everyday use or gaming you won't be anywhere near that...
Delid is simple...do you have the disposable cash for a new CPU? Yeah...go for it...get a delid tool...be careful...easy enough to do...
If not don't...because you void warranty and it's easy enough to bork too!
Easiest performance increase would be getting your RAM to run at rated specs...what's up there? You mixed kits or something?
I don't have that platform so the svid thing I have no idea...wrt enabling disabling
However that won't be affecting your temp readings
Unfortunately having no definite label makes things harder but 56 looks like VRM temp maybe? and 50 for PCH is pretty normal in a case.
03-07-2018 06:13 PM #5
calle trento
Thanks for the responses, lads.
Regarding my ram kit, no - i'm not mixing ram. I'm using the g.skill trident z rgb 2x8gb @ 3200 (cl 16).
Perhaps XMP is a little wonky because I'm using an older bios version though. Maybe I should've tried upping the voltage. Again, I'll do some more tests when I get home from work.
I'll keep you gents posted. Thank you again for the reassurance regarding the mobo temps.
03-07-2018 06:46 PM #6
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,682
If XMP is not working maybe try setting the RAM up manually...3200 should not be much of an ask for that CPU...
Have you tried each stick individually on the correct slot? just to make sure both are good...
03-07-2018 10:24 PM #7
My ram kit is fine as it passed all tests. I should've mentioned prior to posting but the XMP profile works (it's just that I get a double post during cold startups). What's a safe voltage for these kits anyway?
Regarding my OC'd 8700k now.
I've adjusted my current settings.
LLC - 6
AVX Offset - 0
4.8ghz (non de-lidded) at 1.210v
Max temps were 59c running IBT (5 times) and 72c running realbench. Idle I'm at 25c.
http://i.imgur.com/QI209SS.jpg
At stated before - I was able to hit 5.0Ghz stable at 1.290v with an avx offset of 3 - I just didn't like the temps, nor the fact that I was using an avx offset. For myself, using an avx offset is cheating.. I'm sure I could achieve 5.0Ghz with a 0 avx offset at 1.35v, but I have no plans on de-lidding (at least not yet) so I'm completely fine with my current settings/temps. Moreover, the 200mhz difference is very negligible in the real world.
Is using an LLC of 6 too high for this voltage? Should I drop it to 4-5? Sorry for all the questions.
03-08-2018 02:35 AM #8
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 118
the voltage "ceiling" on ram kits is actually based on the CPU (and is set by Intel, not the ram mfr), coffee lake is fine at 1.4 to 1.45V VDIMM. To clear XMP you really need to CLRCMOS to remove all xmp programming. After that, just enter the xmp timings and voltage manually. AVX is trhere so you can run a higher clock for 99% of the time, and down clock when AVX is in the stack. Server class cpus have done this, without any user control for a long time.. and it really necessary for high core count x-class cpus.
However.. "smoke 'em if you got 'em". :P
did you read the guides in the link provided? Use LLC 5.
03-08-2018 02:43 AM #9
meankeys PC Specs Motherboard Rampage VI Apex / Maximus IX APEX / Rampage V EX V10 Processor 7920X / 5960X / 6950X / 7700K Memory (part number) G.Skill Trident Z - 16GB Graphics Card #1 Zotac 1080 Ti Graphics Card #2 Zotac 1080 Ti Graphics Card #3 ASUS STRIX GTX 1080 OC Monitor 3 X ASUS V248Q Storage #1 Samsung 950 Pro CPU Cooler Cool Express SS Power Supply Thermaltake Tough Power Grand 1200W Keyboard Cyberus Headset Tittan OS Win 7 64bit Network Router ASUS
- Join Date
- Apr 2013
- Reputation
- 104
- Posts
- 1,553
03-08-2018 08:41 AM #10
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,682
That is perfectly normal for these boards...just part of RAM training, as I understand it, at certain settings. Nothing to worry about..not a malfunction.
AVX offset isn't cheating...it's sensible management. It's like saying a guy working in a field is cheating, putting on a hat when the sun comes out...
