03-06-2018 02:53 PM - last edited 3 weeks ago by ROGBot
03-07-2018 02:28 AM
03-07-2018 02:25 PM
Marcello.S wrote:
Hi mite_jan, do your fan spin normally under load? Or this behaviour is registered under load as well?
As far as I know for the 980 Ti from Asus there are 3 versions: Strix, Poseidon and Matrix Platinum.
03-11-2018 11:53 PM
mite_jan wrote:
that is correct but from the matrix series should be one only matrix and matrix platinum i think
under load is fine second fan activates
just i want to disable that one fan when idling no need to be working
03-12-2018 02:39 AM
Coolguy906 wrote:
You can try use GPU Tweak II to set your own Fan curve
https://www.asus.com/us/support/FAQ/1035020/
03-13-2018 06:52 PM
mite_jan wrote:
hi
i dont want to set a custom curve
very strange the card waits to reach around 75 degrees and than activates the second fan
that is too high for my liking
03-14-2018 02:52 AM
mite_jan wrote:
hi
Chino wrote:
You can always set a more aggresive fan curve.
