Has anyone run Noctua A14 fans on Rampage VI extreme?
Marko911
Hi,my noctuas and this mobo seems that they don't work well together with or without AI Suite III newest version...Fans spin up and down all the time,at extreme speeds at idle...Did I do something wrong?Did I overlooked something? How noctua fans behave on your RVIE? I installed them first on fan splitter six of them on high amp header,than I used seperate fan headers same problems.When I tried NZXT fans works better,like I can make my own PWM curve but still ramping up and down at idle happens.Than,I bought new noctua fan,same model,same problem....I'm trying to use mobo fan headers to get rid of cable clutter in my case brought by fan controllers.Thanks in advance for the help.
Hopper64
Level 15
I’m using this:
*https://modmymods.com/aquacomputer-aquaero-6-lt-usb-fan-controller-53234.html
Takes a while to learn how to use it. Once you do, you won’t go back. Run a few fans off each header. Small and can hide anywhere in your case. I don’t run multiple fans off the motherboard. Hope this helps.*
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
Hopper64 wrote:
I’m using this:
I know about aquero,and I decided against it.I'm done with non-user friendly devices.I appreciate your advice,it's great solution for someone who have time for that and space in case. 🙂 I was hoping to use some of the features on this mobo,like fan headers.
