Results 1 to 5 of 5
    New ROGer Array Muhammad Omman's Avatar
    Sep 2016
    4
    Urgently Need eSupport Folder for G752VS-GB096T Please Help!!
    Hi, Please help me to give this eSupport Folder i Just install windows 10 pro and i forget to backup the eSupport folder so please help me to give this....Also Asus support website too many files are missing i already check...
    New ROGer Array
    Aug 2017
    5
    have you simply just checked on Asus driver website? There may some of the software drivers etc over there. Was the esupport folder filled with drivers etc? if so just grab everything you need again from the driver page which refers to your model
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    74
    2,408
    isn't this you post with support folder ?
    https://rog.asus.com/forum/showthrea...752VS+esupport
    Sep 2016
    4
    Need Only Recovery Backup ISO
    Actually I don't have it before and now I just have only the eSupport folder but if some one have the ASUS G752VS Orginal Recovery Backup usb iso or something else please provide me...because the original Recovery have asus default some application and setting that I need. Thanks..
    ROG Member Array Feralant's Avatar
    Dec 2017
    5
    Quote Originally Posted by Muhammad Omman View Post
    Hi, I dont know if my esupport folder will help but I do have it. Do you want it?
Tags for this Thread
