Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    New ROGer Array
    Nov 2016
    8
    Speed issue with Raid 0
    My system has the following specs
    Zenith Extreme with 1950x Threadripper
    128Gb Ram
    8 x Samsung Evo 960 nvme drives in Raid 0
    2 Asus Hyper 16x Cards
    Currently I have the 2 Hyper cards full up with all 8 drives, but I have tried various combinations of drives on the board and DIMM card, but it's not much faster than a single drive. It works, it boots, everything looks normal, it's just not as fast as it should be. It's averaging around 4500-4800 MB/Sec.
    I have what looks like the same config as the der8auer video, but I'm just not getting anywhere near the speed.
    I'm running out of things to try and I could use some ideas.
    New ROGer Array
    Jan 2018
    14
    First off, *drool* over the 8 x 960 pros lol.
    What version of UEFI?
    All drives on the latest FW from Samsung?
    Both slots hosting the HyperX cards set to NVME raid in UEFI?
    Pure UEFI environment or using CSM?
    Checked the write cache settings in Device Manager?
    Checked the array details in RaidXpert2 in Windows? It shows a lot more info about the array than UEFI.
    Download HWiNFO64 and check that each drive is getting it's full x4 of bandwidth. Even in a RAID you should be able to see the lanes assigned to each one. Here you can see my 2 x 950 Pros in RAID 0 getting x4 each (about 4/5 of the way down the list):
    These are the common things I can think of. It sounds like they're being starved for PCIe bandwidth. Below are my speeds on 2x 512GB 950 Pros on the DIMM.2:
    New ROGer Array
    Nov 2016
    8
    Thanks for the reply.
    They're not Pros, just Evos, but still pretty nice drives
    Using 0902
    All drives updated to the latest version
    Both slots set to NVME Raid for the HyperX cards
    CSM is diabled, but I tried with it enabled and it didn't change anything
    Write cache is enabled
    Everything looks right in RaidXpert2
    Check HWinfo64 and verified all drives show X4
    I agree it looks like it's starved for PCIE bandwidth, but the Threadripper has 64 lanes. I'm using 32 for drives, and 8 for my GPU. That should leave 24 for system use and all other devices.
    And looking at your speeds, you are doing better with 2 drives than I am with 8.
    New ROGer Array
    Jan 2018
    14
    Really weird! Definitely have plenty of lanes left over. Tried swapping around slots just for good measure? You said you'd tried putting a couple of the drives on the DIMM.2 and it didn't change anything? Would eliminate a problem with at least 1 of the HyperX 16 cards. Hmmmm.
    New ROGer Array
    Nov 2016
    8
    I've had the cards in different slots, tested them individually, and one at a time.
    Originally, I had one on the board and 2 on the DIMM.2 but I didn't bench them. I might try that again.
    I have no idea what's going on unless I'm seeing a driver or BIOS issue.
    New ROGer Array
    Nov 2016
    8
    I'm starting to suspect heat. I re-arranged my fans and now I'm actually getting lower with no other changes.
  7. #7
    New ROGer Array
    Jan 2018
    14
    Don't the cards have built in fans? Is there enough cool air flow inside the case to supply them? If you suspect heat I'd remove the covers, prop a couple fans up in front of the bare cards and run some benches.
  8. #8
    New ROGer Array
    Nov 2016
    8
    They do. That's how I thought it might be heat related. I turned off the fans and it performed worse.
    I probably need a new case. I originally got this one a few years ago when I had 6 mechanical drives in it, so it's optimized to cool drives, not the slots. Probably time to invest in a new case.
    I also have one configuration left I could try that moves all the drives away from the video card, but it puts all of the drives on one side of the CPU, and I'm not sure if that will work or not.
    Edit for clarity:
    What I mean is that each side of the CPU has 32 lanes. From my understanding, you lose 4 off the top for system use, leaving 28. That means I can't put all 8 on one side. I can put 2 drives back on the DIMM, and put the video card on the same side, but it still means I can't put 4 drives on with it, or I have to run my video car at x8, which I am now in the configuration it's in anyway, so probably not a big deal.
  9. #9
    New ROGer Array
    Mar 2018
    8
    Same boat ... poor performance 4x 960 Pro's on Hyper M.2 x16
    Not where it should be ....
    what's next?
    HW-info
  10. #10
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    compatible models for Hyper card
    ROG RAMPAGE VI EXTREME
    ROG RAMPAGE VI APEX
    ROG STRIX X299-XE GAMING
    ROG STRIX X299-E GAMING
    PRIME X299-DELUXE
    PRIME X299-A
    TUF X299 MARK 1
    TUF X299 MARK 2
    There has never been official support for AMD but an updated driver was suppoed to make it possible.
