Results 1 to 6 of 6
03-13-2018 09:41 AM #1
- Join Date
- Mar 2018
- Reputation
- 10
- Posts
- 3
Maximus X Formula does not boot with more than 2 DIMM
Hi all,
Got a brand new Maximus X Formula here with a set of GSkill F4-4133C17Q-32GTZR.
No matter what I do, system will only post with 1 or 2 DIMMS in channel B (B1 and B2). Channel A (A1 and A2) does not post with any combination of DIMMS. (Code 55)
I'm on the latest BIOS (1003) and have tried:
- Clearing CMOS
- Reseating CPU 3 times.
- Checked for bent pins (none)
- Explicitly setting DRAM frequency to 2133.
At one point I tried without a cooler and it didn't post. I put the cooler back on and it worked once then stopped working again. I'm about to give up and RMA unless anyone has any other ideas.
Thanks,
TC
03-13-2018 12:38 PM #2
Deepcuts PC Specs Motherboard Asus Maximus X HERO BIOS 1901 Processor Intel i7 8700K @ 4.7Ghz 1.215V Memory (part number) CMR32GX4M4C3466C16 @ 3200Mhz 1.360V Graphics Card #1 Asus Strix GTX 1080Ti OC 11GB Sound Card Creative Omni 5.1 USB Monitor Dell 24' S2417DG Storage #1 Samsung EVO 960 nvme 500 GB Storage #2 Seagate NAS 8TBx2 CPU Cooler NZXT Kraken X62 Case Fractal Design Define R5 Black Power Supply Corsair AXi760 Keyboard Razer DeathStalker Chroma Mouse Razer Abyssus OS Windows 10 Network Router Mikrotik
- Join Date
- Jan 2014
- Reputation
- 13
- Posts
- 245
I've seen some users with such problems cause by over-tightening of the CPU cooler which bent the motherboard.
Maybe check that? Just an indea.
Also, my X HERO is also a bit finicky with RAM. If I do not push it a bit harder in the slots, system will not post, even tho eyeballing the stick, they look pushed to the max.
03-13-2018 06:12 PM #3
- Join Date
- Mar 2018
- Reputation
- 10
- Posts
- 3
OK well, guess bent socket is what it is. I can get the system to post with 4 DIMMs if I take the CPU cooler off.
I tried putting the CPU cooler on and held it down with my finger and no screws, it doesn't boot. Love it.
03-14-2018 05:51 AM #4
Check to see if the cooler has bitten into the PCB. Have seen cases where people didn't mount the cooler correctly (or left out the washers), resulting in trace damage.
08-22-2018 11:36 PM #5
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 21
I have that exact same RAM and board.
Maximus X Formula with F4-4133C17Q-32GTZR kit
Works 100% under Bios 1602 and XMP Profile.
In fact running 8700K @5.1GHz @1.41v with 75c load Cooled by EK
RAM with all 4 sticks @4133MHz CL17-17-17-37 1.40v XMP 2.0 Profile
Sounds like you broken a pin... Should work right away @2133MHz 1.20v before XMP Profile settings.
08-23-2018 04:45 AM #6
Mr. Fox PC Specs Laptop (Model) - NA - Motherboard EVGA Z490 Dark K|NGP|N Processor i9-10900KF @ 5.6GHz Memory (part number) 16GB Patriot Viper DDR4-4000 @ 4600 Graphics Card #1 EVGA RTX 3090 K|NGP|N Monitor Predator XB271HU 2560x1440 165Hz Storage #1 512GB 970 EVO x 2 (OS Boot Drives) Storage #2 960GB Samung Enterprise NVMe SSD x 2 | 2TB HDD CPU Cooler MO_RA 360 Radiator +1/2 HP Water Chiller Case Praxis WetBench Power Supply EVGA SuperNOVA P2 1600W Keyboard Corsair K95 RGB Mouse SteelSeries Sensei Wireless Headset Skullcandy Crusher Wireless S6CRW Mouse Pad Black Anodized Aluminum Headset/Speakers Logitech Z506 5.1 Speaker System OS W10 Ent LTSC 2019 / W7 Ultimate (Dual Boot) Accessory #1 Hailea HC-500A 1/2HP~790Watt Water Chiller
- Join Date
- May 2018
- Reputation
- 41
- Posts
- 127
I have a similar issue and I am about the RMA my Maximus X Hero (WI-FI AC) for the second time. Everything worked perfectly with my 4-stick 32GB Corsair Vengeance LPX 4000 memory kit up to 4200 CL17 for months. When I flashed from 1101 to 1602 everything immediately went haywire and now I can only use 4 sticks up to 3800. But, 2 sticks work fine up to 4200 CL19 in either pair of DIMM slots. Downgrading to 1101 or earlier BIOS using a normal flash or BIOS Flashback does not restore previous functionality. The Intel ME firmware version does not downgrade along with the BIOS version.
What is different in my situation is slowing down the RAM to 3800MHz corrects the problem with 4 sticks installed and removing the water block to relieve pressure on the CPU doesn't change anything. Booting at 4000 or 4200 with 4 sticks is not an issue either, only problems involving Windows file corruption, Windows Boot Manager not being found, and random BSOD, with 4-sticks installed running higher than 3800MHz.
The only thing I can identify that caused the system behavior change is the new Intel ME included with 1602. I skipped over BIOS 1401 (which also had the newer ME version like 1602). The only reason I bothered flashing 1602 was the intent to upgrade to 9900K, and now I regret updating the BIOS.
My normal approach to drivers and firmware is "if it ain't broke, don't fix it" and wish I had stuck with my normal M.O. now. The latest is often not the greatest where drivers and firmware are concerned. Hindsight is always 20/20, LOL.
This does sound like a hardware issue in your case.Last edited by Mr. Fox; 08-23-2018 at 04:54 AM.
WRAITH // EVGA Z490 Dark K|NGP|N | Core i9-10900KF @ 5.6GHz | Optimus Signature Water Block on Bare Die | EVGA RTX 3090 K|NGP|N | 16GB Patriot Viper 4 Blackout DDR4 @ 4600 | EVGA SuperNOVA 1600 P2 | Hailea HC-500A (1/2HP~790W) Chiller | MO-RA3 360 Pro Radiator | Dual XSPC Photon 270 | Windows 7 Ultimate > Windows 10 Enterprise LTSC 2019 > Windows 10 Enterprise 2004 Cancer Edition > Linux Mint
