Results 1 to 4 of 4
    ROG Guru: White Belt Array
    Jan 2015
    107
    G751 Battery Pack rebuild - need advice
    I would like some advice on rebuilding the battery pack of the g751, I do have some experience with things like this but not too much. I know the basics about batteries and how to work with them. The thing I would like to know is: is it even possible or does the circuit stop working as soon as it detects 0 volts? Any one here has experience with it? I already went through 2 OEM packs, both died after 12 months. It's not completly dead yet but it does not charge past 86%.
    For me it would be cheaper and maybe longer lasting to just rebuild one of the packs with some quality cells.
    Laptop: G751JL
    Processor: i7-4750HQ
    Graphics Card: GTX 965M
    Memory: 8 GB Samsung (stock)
    Storage #1: Samsung 850 EVO 250gb
    Storage #2: 1 TB 7200 rpm (stock)
    OS: Windows 10 x64
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,182
    Since you have changed out one battery pack, you have the cartridge from the first so you also know what batteries you need use to replace them. Why wouldln't it work. I've seen several others do this on other G series notebooks successfully.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Jan 2015
    107
    Quote Originally Posted by Clintlgm View Post
    Yeah, already took the old one apart. Just wanted to be sure before ordering the cells.
    Laptop: G751JL
    OS: Windows 10 x64
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,830
    As long as the cells have a minimal charge the circuit will pick them up. If they are almost dead when you install them then it may disable the group but a bit of manual pre-charging would rectify that. Most cells ship with a partial charge anyway as storage at low charge state is bad for them so it shouldn't be an issue. It may take a discharge cycle to accurately calibrate.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
