03-14-2018 06:33 PM - last edited on 03-06-2024 09:09 PM by ROGBot
03-15-2018 01:02 AM
03-15-2018 03:48 AM
03-15-2018 05:09 AM
03-15-2018 05:39 AM
ashsupra wrote:
Thanks for the replies
I've tried without hdd attached and still nothing
Can't get to the bios at all nothing on screen.
Also when I press the MEMok button on the motherboard it all switches off for a couple of seconds and reboots. Still nothing
03-15-2018 06:52 AM
03-15-2018 01:01 PM
03-15-2018 04:37 PM
ashsupra wrote:
hi guys thanks for the replies
I decided to try a different tv, I used a 32" hd tv instead of my 4k tv too see if it helped
harddrive back in and I managed to get into the bios, I followed on then to install windows 10 which has all been installed with no issues.
I then updated my drivers and tried my larger tv again and now it works
not too sure what the issue was but I have another question
ive installed the monitoring software for the kraken and noticed my cpu spikes randomly and temp rises slightly during these spikes
I then installed cpu-z and hardware monitor to check and all cores randomly spiking all over the place every couple of seconds
I have read around the internet and some say its completely normal and some guys say its not.....
so now I'm confused
I decided to use the ez tuning wizard in the bios which increased ram speeds and cpu speeds slightly and it hasn't done anything to help the spikes
is it normal for this to happen? jumps from around 800mhz to 4000+
03-16-2018 01:10 AM
03-16-2018 05:04 AM
