pg258q light flickering
ahmedpc03
Hi
i purchased asus pg258q a day ago
i noticed during loading or when starting the game play .... there is a light flickering a little bit then its gone, back to normal after a second
i just want to make sure if this is normal or not, should i returned the monitor and asked for replacement
disabling gsync there is no light flickering
Leonidas44
Yeap because the fps drops too low then and the gsync gets a stroke , every gsync monitor i tried had this issue so you will have to accept it.
I guess in the next gsync gens all this issues will get fixed 😉
ok thanks 🙂
