Page 1 of 13 1 2 3 11 ... LastLast
Results 1 to 10 of 128
    ROG Guru: White Belt Array Fear4u2envy PC Specs
    MotherboardAsus mamimus x hero (WiFI)
    ProcessorIntel I7 8700K
    Memory (part number)Gskillz Trident 32 Gigs 3200Mhz
    Graphics Card #1EVGA 1080TI FTW3
    MonitorAsus ROG SWIFT PG348Q
    Storage #1Samsung M.2 500gig
    Storage #2Samsung M.2 250 gig
    CPU CoolerEKBW custom cooler
    CaseThermaltake tower 900
    Power SupplyEVGA super nova 850G2
    Keyboard Logitech Wireless
    Mouse Logitech Wireless
    Headset/Speakers Bose Computer speakers
    OS windows 10
    Fear4u2envy's Avatar
    Mar 2018
    78
    Need a little help overclocking my 8700k
    Hi Nate152 I was wondering if you could help me over clock my 8700k.
    I was following the posts when you were helping out Drecan.
    Here are my specs:
    asus maximus x hero (WIFI)
    Intel I7 8700k
    EVGA 1080TI FTW
    32 gigs Gskillz trident 3200Mhz
    EVGA 850W supernova G2 power supply
    Samsung M.2 500gig SSD
    Kingston M.2 250gig SSD
    Samsung 500 Gig SSD
    Samsung 250 Gig SSD
    Asus ASUS ROG Swift Curved PG348Q Gaming Monitor
    EKBW custom water cooling
    OS windows 10
    Mar 2018
    78
    Anyone?? Lol
    Thank You
    S. Pow
    OS windows 10
    Mar 2018
    78
    Is there anyone that could help me out?
    Thank You
    S. Pow
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Fear,
    You can probably review the other posts by Nate and try the same settings but I will try and help until Nate gets on.
    You have built an awesome looking PC with excellent components. Let me ask a couple questions first.
    What is your intended use - Gaming, daily use, WORK, sorry for the 4 letter word
    Has your CPU been delidded?
    How much OC are you hoping to reach?
    Model number for the memory kit?
    What are your current CPU temps under load?
    I just posted all my bios settings for a X Apex https://rog.asus.com/forum/showthread.php?100985, basic settings are same for Z-370
    OS windows 10
    Mar 2018
    78
    Hey Menthol, I was following one of the posts that Nate was working on but I got to a point where my voltage was lower and the person he was helping was higher so he had to go into a different direction then I needed to and that's where I stopped.
    to be honest 4.9 is fine with me even 4.8 as long as the voltage is not crazy. I was looking into deliding I even purchased the tools but just don't know if its the right thing to do. as for the memory its 4 dims of Model F4-3200C16D -16 GTZB (32gigs total) also the system is for gaming and some video editing max 2k (3440x1440)
    Here is a screenshot of stock temps under load
    Thank You
    S. Pow
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Hwinfo is a very good APP but to me it's information overload hurts my little tiny brain
    I would suggest enter 1.3 volts vcore and try 4.8 GHZ, with AVX offset -2, run RB, if stable and temps are OK, try 4.9, 5.0 if you are extremely lucky
    Your per core temps are close so your cooler mount must be very good, that's a plus
    I'll check back in an hour or so to see what happened
  7. #7
    OS windows 10
    Mar 2018
    78
    ok ill try those settings, Is there another app I should try if that app has too much info
    Thank You
    S. Pow
  8. #8
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Use whatever app you are comfortable with, probably not best to change if you know what you are looking at
  9. #9
    OS windows 10
    Mar 2018
    78
    Well I only started this a few days ago looking at Nate’s posts but I learn really quick and I know about Vcore and certain temperatures to look for. not too sure what’s a dangerous temperature to be at or what’s a dangerous voltage to be at I see a lot of people staying between 1.35 and 1.38. I also don’t want to burn out my processor with in a year and if Deliding is a good route to go hey I have to try something once at least right.
    Thank You
    S. Pow
  10. #10
    OS windows 10
    Mar 2018
    78
    Ok here are the results, 1.3Volts Vcore 4.8 GHZ AVX offset -2
    Thank You
    S. Pow
